The Treeline '97 rally had a tie for first place overall, measured to the hundredth of a minute, between Ray Hocker/Lynette Allison and Ron Wood/Kelly Walsh (if memory serves.) As a result, the CRS specifically wrote a tie-breaking rule.
For some reason I thought the SCCA used a different method for tie-breaking at Maine, but now I see that it matches the California Rally Series rules after all, at least for an event. I haven't checked to see what the SCCA uses for year-end championship ties.
From http://www.californiarallyseries.com/2003_CRS_rules.pdf
TIE BREAKING:
In the event of a tie at an event, both competitors will be given the points for the tied position. The next placing competitor will
be awarded points appropriate for two places below the tie. Example: A tie for second will give both the tied teams 80 points (2nd),
and the next placing team will get 50 points (4th).
In the event of a tie for a year-end ranking the tie will be broken by adding all the points accumulated in triple points events
which both competitors started in the class in question. All events started will be counted (no events will be dropped). If this does
not resolve the tie the same method will be applied to the double points events. If a tie still exists the same method will be applied
to the single points events. If the above method fails, the tie will remain.
[hr]
[p align=right]John Dillon
John @ WidgetRacing.com
www.WidgetRacing.com
TIE BREAKING:
[hr]
