41 - 60 of 65 Posts
Discussion Starter #42
Thats awesome.
Dean, could you message me and ill hook you up with a time and my number.
Same with those other guys, thanks!
I'll give soapy a call tmrw, i never knew he raced these, although i did see an old datsun or bmw(couldnt tell what it was at 55) outside his shop, looked like an old rally car...
Discussion Starter #43
Starting going through brakes on the car today, plus drained the gas tank.
now, to pull the gas tank out, do you have to drop that rear beam to pull the tank?
Look at that varnished gas!
isnt it a pretty color?
I don't think the rear beam has to come out. The exhaust might have to be dropped, though.
If you wanted you could pull the fuel level sending unit first; that should give you enough of an opening to inspect the inside of the tank with a mirror and decide whether you really need to drop it. The sending unit is accessible from a removable plate under the rear seat. (Well, in the rear seat area; I'm guessing this car doesn't have the actual seat anymore!) It's a good idea anyway because the intake and pre-pump (if equipped) are also attached to the sending unit, and the hose connections and prefilter in there are prone to deteriorate over time.
Discussion Starter #45
got the gas tank dropped, gonna be going through the brakes tmrw.
we did need to drop the beam to get the tank out though...
anyone know where to find a good in line electric fuel pump that will put out enough psi for the FI rabbit?
and do they make fuel cells that fit into the spare tire spot?
i heard the diesel rabbit use to have one there
Spectator Wrangler
One of the problems is that this is a CIS car. CIS is a semi-mechanical Fi system that runs at a higher pressure than a typical EFI. Airtex does make some inline pumps that are supposed to have the correct CIS pressure. 1988- 19901 Audi 80/90 4/5 cylinder cars would work. Audi 4000 pump are also external to the tank and would work. Sourcing fittings can be an issue though.
Having said that, I did have problems making a 20 valve Audi run correctly with an Airtex pump. A swap to an OE Bosch pump fixed the problems.
Discussion Starter #47
so just buying another stock rabbit fuel pump would work?
and could i do away with the accumulator if i ran a fuel cell?
My bad. I was going by the manual I have, which didn't mention needing to drop the beam, but it wouldn't be the first time it was wrong. I think you also have a considerably earlier model than I'm used to, so even though it's the same chassis there may be differences.
If you're talking about the accumulator that's plumbed to the fuel pump, in CIS it's mostly there to make hot starts easier. Together with the check valve it keeps pressure in the system after the pump is shut off, so the fuel won't boil in the lines from heat soak.
Spectator Wrangler
Stock pump is fine. When you asked about the inline pump, I thought that the OE pump was one of the in-tank units. CIS was used in most German/Swedish cars in the late seventies to mid-eighties. It often used two pumps. One was a pre-pump which kept a constant fuel supply to the main pressure pump. The pre-pump was always in the tank. The main pressure pump was sometimes in-tank and sometimes external depending on manufacturer and year. I don't remember which the early Rabbits used. If the main pump is intank, it will take some work and imagination to put a cell in.
I haven't been an import car parts specialist for 10 years now and it's fading away.
Discussion Starter #50
alright, sounds good.
the car (what year is it?) issue is still a mystery.
i ran the vin number, thats tagged on the dash..
its 177335714
heres the place where i ran the vin..
http://www.dubnetworks.net/vw-vin-decoder.htm
but doesnt it have an 80's ass end on it?
i didnt think they had gti's in 77?
any info would be great, thanks.
Spectator Wrangler
its 177335714
Yes, that's a 1977 VIN. 17x indicates Rabbit/Golf and XX7 (1977). VINs changed to the 11 digit format in 1981. Back half of the car appears to be a Westmoreland,PA. produced car. GTIs did not come to the USA until the 1983 model year. GTI badged round headlight cars were available in Canada before then. Mostly a trim package, no real performance parts. Definitely not the "hot hatch" GTI available in Europe although it looked like it. A GTI badge is just held on by tape so it can go anywhere. It was common in the time to make your car look like a "real" GTI as possible.
Remember that you have a rally car. It could have been "reshelled" after an accident. It could have recieved the "identity" of a donor car after being built out of pieces from many cars. After all, the windshield VIN usually just pop-riveted in place. Cars usually have the VIN in more than one place as an anti-theft measure. I'd try to find a VIN in one of those "secret" locations to determine the identity of the shell.
Your real job is not the "real" year but to figure what year most of the parts came off and write a list. Perhaps the VanDammes remember where the parts came from. You need a VW person to look and point at a part and say "This came from".
Discussion Starter #53
oh yeah, there's a thread on the car on vortex, but they either..
ripped on the car because it was cut up into a race car
thought i would never get it running
thought i didnt even own the car
or just some other negative comment.
so im done on there
Allrighty then, it's time to ask the VanDammes.
I'll betcha some of them will be be in Houghton Oct 15-16.
You are coming to lsPOR, aren't you !?
http://www.lsprorally.com/
If you ask Bertagnoli nicely, I'll bet he would let you work with them.........
so im done on there
Discussion Starter #55
oh hell yeah, i'll be there, so will my autos teacher...
dropped rear beam completley, gonna paint it, started removing fenders for rust repair...
Rabbit parts!
Under the think dust and grime, the engine dont look to bad. you can see a sneak peak here...
Discussion Starter #57
its clean, for the most part...
my first rally car was the best of three rabbit
the shell i bought from the local vw guy for $50.00 with a good title chrome stick on stuff around the bottom no interior and power train it reecked of cocobutter
the engine and trans came from a diesel rabbit convert with no floors anf the cage and other bits from bob campbells groupe a rabbit that had died years before on stage in a head on with a large tree
bob and i are not small people and it was tight in side that car
i had one guage the engine temp
at tech the guy rev it to 4 grand for a sound check
i replyed "i can set the clock at 4"
i drove the car to the ohio valley forest rally (i think) rallyed all night then drove the 2 hrs back to charleston wv
one more car i miss from time to time
keep up the posts
there are some good folks on vertex but most are posers
Discussion Starter #59
here's some pic's...
(rear hatch tray area, back trunk area)
You guys on vortex are gonna kill me, but we're running a keg gas tank in the car.
yeah. i know... fumes, leaks, cabin smelling like gas, why would you do that to an mk1, blah blah blah...:thumbdown:
thats what were gonna be doing, unless somone can hook me up on a killer deal on a fuel cell...
scored some junk yard subie seats for 20 bucks... gotta rig up a system for installing them now.:facepalm:
good news... the engine is cleaning up nicely.. pics of that tmrw.[/QUOTE]
Jason McDaniel
...You guys on vortex are gonna kill me, but we're running a keg gas tank in the car.
Do you intend to Rally this car? Or just spectate with it?
If you want to enter this car in a Rally America event, it either has to have the OEM tank or a fuel cell. And it has to have one piece seats.
41 - 60 of 65 Posts
