Status
Not open for further replies.
1 - 2 of 2 Posts
SEE PICTURES ON IG - @madrallyteam, Cars/Trailer/ALL spares $28K obo
ARA Logbooked Car + 17' 2-axle Trailer, Spare Titled 2001 2.5RS coupe rolling chassis (great condition), full spares
CAR (Build started in 2018 finished in 2019)
1998 Subaru Impreza 2.5RS coupe (ARA logbooked in 2019), current historical registration in Maryland
REIGER 3-way gravel suspension w/remote reservoirs (like new)
TIG welded FIA spec rally cage (must see!)
TIG welded sill pin stand inserts (includes 4 sill stands)
Stock Engine internals, good compression (engine rebuilt in 2016, 3 races on engine since rebuild)
WeaponR CAI
2005 JDM WRX transmission w/20kg ASD center differential, close-ratio RA gearset, 4.44 final (new build in 2021)
ACT streetlight flywheel & clutch (new in 2021)
Fluidampr harmonic balancer
4.44 LSD
PTFE SS fuel lines with AN6 connections
Rebuilt knuckles w/new bearings and ARP long wheel studs (2021)
GC8 4pot/2pot brake calipers (rebuilt with new seals/pistons 2021)
Wilwood master cylinder w/vac delete
PTFE coated SS brake lines
Wilwood hydraulic e-brake
L&E quick steering column
230 Amp alternator (new 2021)
CSF aluminum radiator + new rad hoses (2019)
2 X Spal fans
AC + cruise delete
hood struts
hood pins
trunk spring latches
PTFE coated SS clutch hose
ALL Bushings replaced with Whiteline (WL) bushings
WL Anti-roll bump-steer kit
WL tie-rod ends
STI Group N dog bone
STI Group N engine mounts (2021)
STI Group N transmission mount (2020)
Cusco rear subframe brace
Beatrush rear subframe brace
Front aluminum skid plate
LSD skid plate
Full UHMW-PE underbody protection bolted on with welded inserts
Odyssey AGM racing battery (relocated to trunk)
Windshield wash reservoir relocated behind driver
2 x OMP HTE-R halo racing seats
OMP aluminum clutch/brake/gas pedal grips
OMP WRC steering wheel with functional horn (Hella)
OMP co-driver foot rest
2 x Sabelt FIA certified 6 point harness
Sparco intercom w/cord to record in-car comms
Flocked dash
4 x hi power USB outlets
Mini, ultra-light racing heater core w/ 2-speed fan
2 LED interior lighting circuits (white and red)
TerraTrip GPS/GLONASS rally computer
RallySafe mounts/wiring/antenna
LIFELINE 2000 4L 8 nozzle (4 interior/ 4 engine) manual fire suppression (Recertified in May 2021)
2 x handheld fire extinguishers
Helmet hammock
Co-driver pouch
Mud flaps
Hella driving lights
12" LED light bar (new, not installed)
Evo Corse 15" wheels w/Hoosier rally tires
ARP wheel studs (long)
Lugnuts, open-ended (OE), forged
1 x Evo Corse 15" wheel spare w/new Federal rally tire (in-car)
Jack
Spill Kit
1st Aid Kit
3 x Emergency Triangles
SPARES
2001 2.5RS COUPE, TITLED, rolling chassis w/wiring harness, ECU, doors, hood, trunk (build a second car!)
4.11 5psd transmission w/LSD
Exedy Stage1 clutch w/lightened flywheel
4 x Evo Corse 15" wheels (gold) w/Hoosier rally tires
4 x 16" Subaru alloy wheels (put on winter tires for rally cross)
4 x 16" Speedline Wheels (gold) w/Bridgestone Pilot street tires (very good)
GC8 lightweight aluminum hood
GC8 trunk lid
GC8 front cut (bumper/grill/driving lights)
5 x front CV axles
5 x rear CV axles
2 x steering racks
3 x front bumpers
2 x rear bumpers
1 set front control arms
2 x sets rear trailing arms
1 set rear front lateral links
1 set rear back WL adjustable lateral links
3 x sets stock 2.5RS front calipers (1 set is new)
3 x sets stock 2.5RS rear calipers (1 set is new)
2 x full sets of rotors for 2.5RS stock brakes (new)
2 x full sets of brake pads for 2.5RS stock brakes (1 set new)
1 4pot front rotor (new)
1 2pot rear rotor (new)
2 x complete sets of knuckles (1 set w/ARP long wheel studs)
1 x set (front/rear) KYB AGX adjustable dampers w/raised King Springs
1 alternator
1 starter
2 x fuel pumps (1 new)
1 x fuel tank (new)
1 igniter (new)
1 ignition coil (new)
1 cam sensor (new)
1 throttle position sensor (new)
4 x fuel injectors (new)
1 set NGK spark plugs (new)
1 set NGK spark plug wires (new)
1 set PS high and low pressure hoses (OEM/new)
1 Gates timing belt kit w/water pump (new)
2 x alternator/ps belt (1 new)
1 set (front/rear) heavy-duty track stabilizer bars w/endlinks
2 x full sets of OE lug nuts (1 forged steel/1 aluminum)
8 x valve stems (new)
TRAILER
17' 2 axle closed-deck steel trailer (axles are rated at 3500lb each) all re-wired with new LED brake and marker lights, new brakes (adjusted), emergency brake kit, custom fabricated winch mount, spare tire. All tires (new in 2019) and spare are E-rated for high load capacity and speed.
2 x aluminum ramps
4 x ratchet straps for autos
1 - 2 of 2 Posts
Status
