Poly-urethane lower A arm bushing: JVAB Imports Seattle 206 431 9696
Poly-urethane for especally front shock lower eye: NW Offroad Center, Bellingham WA for 'virgin' poly wich really last better than any others I know, far better than than for example Rauncho. Pain in the drain to deal with as they are 4wd jeep/toyota rip the forest to shreads types but tell them your need 5/8 hourglass bush.
For new correct rally valved,rally length actual 900 Bilstein Front and rear again call JVAB in Seattle, where recently current price info was sent from Bilstein Sweden for 96, 99, and 900.
I can check about availability of front springs specificaly as '900 rally' spring, since it was me who organised a co-production run between the then SaabMasters, now Scan-West, back in I don't know when. I imported some rally springs from Sweden for 99, and sent them to where I have 96 rally springs made, but that was 11 years ago so the data on actual springs rates.
I do know now the the front spring diameter is such that Circle track fronts would sit on your perches and if one of the guys could go out and measure the wire diameter and count coils, we could without doubt get you springs that way. Anybody have a 'veri-near caliper'? 16mm wire? 10.5 turns?
What are you intending to do for strengthening the A arms, something you had better do well. Well means well, not just heavy, you know.
Maybe the poor guy with the MA 900 could post photos of just how their A arm failed at CT, that was the caused listed as DNF wasn't it.
Again JVAB has done thouroughly welded exchange upper and lower A arms for numerous 99/900 guys with zero failures, must have learned something after 3 different sorts of failures on his own, eh?
Maybe its time for a mini-run of A arms.
Too bad i haven't figured out how to post photos yet, I have nice photos of JVAB lower arms. Newbie Prole-le-rallist 'Wild' Billy Milligan and Derek 'Uncorked' Bottles came over yesterday and got the scanner and this click clacky thing working. Today maybe we can post photos?
