I sat down with a friend at lunch today and somehow we got onto the topic of restrictors.
I guess that since they are inevitable, I may as well look for the silver lining in the dark cloud.
Here is what I came up with:
Top cars will be a lot closer in power since no amount of money will produce more airflow through a restrictor once you have the shock wave in the throat. This is a law of nature and physical impossibility. Therefore, the top $$$ guys will have to spend their HUGE amounts of $$$ going after the 'last 5 percent' that is possible for a given airflow.
It *should* separate the true 'drivers' from the 'big check writers' in a pretty decent hurry since many will no longer be able to be 'saved by the throttle' to make up for a mistake or lack of corner speed.
34mm restrictors are already well known in Europe and Canada, so tuning information is not *that* hard to come by and is available to just about everyone who knows what questions to pose to whom.
It will not force us to give up some roads that we *truly* enjoy. In my case, Brooklyn Tavern and Smith Creek. The cars will be slower, albeit marginally, but the *perception* of increased safety should go a long way with the non-rally types.
There are drawbacks, however:
Engines will have to be 'purpose built' and mapped to optimize torque in the midrange since you will 'run out of air' at the top end of the tach. This can be expensive. I'm hoping to build ONE engine that will go a good amount of time between major maintenance and just go with whatever power output I can get RELIABLY. I'm guessing something in the 290-310 range based on my budget.
I'd be *very* surprised if we didn't eventually see something along the lines of the 'Toyota *special* restrictor' at some point, given the money being spent by top teams.
I still don't like the idea, but I guess its deal with it or park it and I like seeing my rally friends on the event weekends.....
I always considered knowing when and how hard to use the brakes part of driver skill, just like controlling the big BHP beast....but I guess brakes will be getting a good bit less use in 2005.
Just some thoughts....YMMV
Matt Manspeaker
Seattle, WA USA
89 323GTX - OPEN
97 Escort Cosworth - WIDE OPEN
Matt Manspeaker
Seattle, WA USA
89 323GTX - OPEN
