1 - 2 of 2 Posts
Caged and log booked 04 Focus SVT Built over the past 5 years. This car started as an SCCA Rallycrosser and is now a podium finisher in the last 5 Team Oneil Rally Sprints. Also has some hill climbs under its belt. NASA Logbook (inspected in 2015)
180HP SVT Engine
PCV delete, replaced with oil catch can Gates timing belt New radiator High temp radiator hose kit Spark plugs and wires K&N air filter VF Engineering mounts New oil pan FSWerks aluminum crank pulley Low temp thermostat Ceramic coated exhaust manifold
Transmission
Quaife differential Clutch Masters stage 4 clutch Clutch Masters aluminum flyweel
Safety
Tig welded cage by Iron Alterations RI with SFI padding OMP RS seats OMP harness 10 b:c extinguisher and bracket 3 caution triangles and first aid kit Rear mounted battery box with battery cut out on dash Hood pins Air horn Custom skid plate Sparco mud flaps Sparco tow straps front and rear
Steering and Suspension
Hot Bits Gravel Coilovers w/ tools OMP steering wheel with quick disconnect SVT quickened steering rack 6 Team Dynamics rally wheels with gravel tires mounted SVT brakes with Hawk HP Plus pads New OEM control arms Reinforced trailing arms with poly bushings ARP wheel studs
Misc
Roof scoop closable Dual GPS/GLONAS for trip IPad mount Low voltage USB ports Stilo intercom HID headlights 3 point spare tire strap Delrin shift knob
Tons of spares including tires, steering and suspension components, body panels, and much more. This is a very competitive car with the Group 2 class that's already proven itself. Take it all and have a blast. $10K OBO call/text 734-545-2606 -Scott
1 - 2 of 2 Posts
