After much discussion, fiddling, and experimentation, I can definitively say that I now know how to hook up a terratrip to the VSS signal on a MY98 Subaru.
1) You do seem to need the DSI box. I haven't acutally tried bypassing the DSI yet, but with the DSI it works.
2) I tapped into the Bulkhead wiring harness within a few inches of the ecu.
3) On the MY98 cars the ECU connector is one large connector with ~166 possible pin locations. The one you are interested in is #83. If you look at the face of the connector with the wires flowing out away from you, 83 is in the lower right corner of the left half of the connector. It is a black wire with a green stripe.
Invaluable assistance came from Scott Puttnam at Bloomington Subaru in Bloomington, MN and from http://www.ravensblade-impreza.com
I haven't had a chance to calc good factor for it yet (we had an opportunity at Headwaters, but other things were pressing) but I reckon that it is between 4750 and 5000.
Interference was not observed from either any of the car's electrical systems, nor from the HAM radio located very near the wiring.
jblewis
jblewis
