1 - 10 of 10 Posts
Sold !!! In Louisiana. (Trade) Would like to get into a 2wd car with a logbook for stage rally. Since I'm a novice,I can't start out with the evo and would just be easier to sale and buy a 2wd car for now.
Car has 132,000 miles.Original motor, transmission, transfer case, and rear diff. I'm the second owner of the car. The first owner was in Florida
Car has a
-Force performance 71hta turbo
-gsc s1 cams
-removed abs and installed Hydraulic hand brake from TRF.
-brake line is ran inside the car
-home made front splitter
-home made rear diffuser
-English racing acd tune
-12 plate weir for the rear diff
-Wilwood front brakes from TRF.
-Stock suspension (Bilstein)
-winterfroce snow tires 185
-also stock bbs rims
- enkie rpf1 are sold. Don't come with car
-braid rally rims from Team illuminate
-battery relocated to trunk
-Rear whiteline 26 swaybar(not installed)
-Car has No interior installed took it out for the cage.
I do have all interior for the car and all heater and air condition parts.I did strip the car for a F.I.A cage but never got the cage installed.
The car does drive and is Louisiana road legal. Some one did back into the drive door in 2014 and I had to replace the drive door outer Skin.
Clean title in hand.
If someone is intrested I will post more pictures of the car.
Video is the old setup on the car. Same engine mods but suspension at time of video was Fortune auto and the wing has been sold and the enkei rims.
https://youtu.be/B4tUZiWOJd8
Sent from my SM-G892A using Tapatalk
Discussion Starter #3
Car is now dual tuned, one at 23psi and the other is 28psi. Compression is 150psi on all four cylinders. The car will race an autocross event October 14.
1 - 10 of 10 Posts
