'Industrial grade' is an over-simplification
I post the following not to express an opinion either way, just as a public service and to show off:
GPS (not GNSS) can be:
- parallel channel or multiplexing (older models)
- high noise (cheap) or low noise (less cheap)
- single frequency or dual frequency
- code-only or code & phase and/or phase-smoothed code
- autonomous and/or code & phase differential (RTK) and/or code differential (DGPS)
DGPS corrections can be:
- differential position corrections (less accurate) or
- PRN observable corrections (corrections calc'd for each code observable from each satellite)
- PRN observable corrections smoothed by carrier phase
They can be provided by:
- another local receiver sending via radio modem, cell phone etc OR by some sort of service
- a wide area service (WADGPS) such as Racal, OmniStar, Satloc, WAAS (free), GPS-C (free), Coast Guard (free)
Lets look at both ends of the spectrum: a Garmin handheld ($200) and a Leica Dual frequency geodetic receiver ($40,000)
Garmin: parallel, high noise, single freq, code only, autonomous or code differential (DGPS), DGPS=position corrections only, some come with WAAS built in, they are capable of being corrected by any of the above-listed WADGPS services given a connection to the appropriate radio or satellite receiver.
Accuracy:
- autonomous uncorrected with suitable sat coverage and geometry 10 to 15m
- WADGPS with suitable sat coverage and geometry +/- 5m
Leica: parallel, very low noise, dual freq., code & phase, autonomous or DGPS or RTK capable, DGPS=individual channel corrections smoothed by carrier phase if available, no WADGPS service built-in, capable of being corrected by any of the above-listed WADGPS services given a connection to the appropriate radio or satellite receiver.
Accuracy:
- DGPS from second local Leica receiver +/- 30cm
- WADGPS with suitable sat coverage and geometry +/- 1m
- RTK from second local Leica receiver with suitable sat coverage and geometry +/- 2cm
A good setup for rallying would be:
A 1 or 10Hz GIS-type single frequency receiver capable of wide-tracking loop for performance under canopy, corrected by GPS-C (highly accurate free service of the gov't of Canada, broadcast on MSAT - proprietary sat receiver one time cost of $1500CDN)
This is a low noise, low latency setup that could provide pretty good time and 1 to 2m DGPS accuracy under sparse canopy. Total cost maybe $5000 up.
Robin
