1 - 8 of 8 Posts
Hello all
Slowly but surely I am continuing work on my Datsun 510. I am installing a firewall between the stock fuel tank and the driving compartment. Here is a pic of what I have done so far. The center portion I need to be able to access if I need to remove fuel lines for replacement or even if I need to replace or remove the tank. Is it allowable to rivet an aluminum sheet over that opening?
Discussion Starter #2
Ok I think I might have found the answer in case anyone else needs the info. Over on Dirty Impreza I found a post that showed the exact question I am asking and nobody seemed to question it at all. I still don't know for sure if it is legal but i will go ahead and do it. The worst case is I drill the rivets and weld in a piece of sheet metal.
Mike G
Thanks I will get some of the caulk and and go over all the seams.
Mike G
Glad to see another brilliant Rally car choice and sad that more parts will be siphoned off of E-bay.:D Our panel came fastened on with sheet metal screws and I never really was comfortable with it. I am in the process of doing what you are but leaving two small rectangular access panels at the tank bolt locations. I have a tube of fire caulk ready on the shelf but have not done a gasoline test on it yet. This caulk is for construction use to prevent fire/heat from traveling from one cavity to another but not necessarily in contact with chemicals. I think even if it gives you a few seconds more time to get out of the car, all the better.
What engine are you going to run with? Post some more pics when you can.
Brad Fast
#727 Datsun 510
Discussion Starter #7 (Edited)
Bfast
I am currently using a L18 with a 280Z 5 Speed. I eventually will upgrade to either a KA24DE or SR20DE but that is in the future. Right now I am trying to get this car together so I can rally. I will post some pics up this week. for now here is what I have done so far.
The previous owner had added speakers in the top tray so there were three very large holes that needed to be covered. I used Alu. there as well. I am going to get a right angle drill from work so i can make the panel a little more tight up against the existing sheet metal. The triangular piece of Alu. is not riveted in yet and i still have some holes to weld up.
Mike G
1 - 8 of 8 Posts
