1 - 18 of 18 Posts
Maybe I missed it, But I don't think I heard why/how the following DNFed?
Doug Shepherd
Matthew Iorio
Pete Lahm
I am not here anymore
>following DNFed?
>Doug Shepherd
>Matthew Iorio
>Pete Lahm
Doug put a hole in some engine or cooling component or something.
Matthew drove his car way off the road. They still might be trying to extract it.
Pete Lahm ripped the rear suspension off.
alan
If the crew would tell us why they DNF'd we put it in the updates.
We currently don't have a reason for the DNF's in the results but we are working on them.
go to the Rally-America.com forums and enter in your wish list for what you want on the web site. Heck we're not busy at all and have lots of time to make changes. :)
But seriously now. A lot of the crews do not come and tell us why they DNF'd so right now there is not much point in adding a field in the results to show why someone DNF'd.
50 L3/CR 70 Yump 200
>>following DNFed?
>>Doug Shepherd - Found out why "Chads yump" ain't so good for landing on the nose - and yes, pushed a bolt or two into the rad.
>>Pete Lahm - High centered w/ some damage to the suspension
(just a bit too much to continue)
Yeah, emphasis on way off the road. Actually after he went in a Club car took the same path, although sweep got him out on the first pass, and he drove out of the stage. Matt's car had to wait til later in the night. The car looked pretty good from what I could see from the road, I think the small trees broke the fall.
>>What, does his program have some sort of DNF Telepathy
>>module?
>No. I think a little bird tells him.
Apparently the Rally America folks are lacking in ornithology...
bruce what would the lease fee be for all the teams to have carrier pidgeons in each car?
they could be easily trained to find the big white truck.
just make sure not to park it too close to the cox family hauler or they will end up like all the codrivers friday night accidentally atracted to the bright lights.
which left?
Check:
http://www.specialstage.com/forum/cgi-bin/DCForumID19/394.html
Mark Holden
KC0SUW
Is that what happened? I was at the jump right before he came through and the cars were not catching much air at all. when Doug came through and pulled off into the spectator area (which was maybe 150 yards from the jump), the car behind him had just about caught him, which made me think the problem happened before the jump, no?
I would never DNF at 'Chad's Yump'. I had my episode about 1.5 miles previously, and it came from understeering into a bank on a L3, downhill.
By the way, contrary to legend Chad did not jump further and harder when he DNF'd, he had just built a trick new suspension arm that bound and failed a heim joint in full rebound when it 'over angled'.
But the 'longest ever' jump makes a better (fiction) story !
ah, ha! I knew it had to have happened much earlier
Do I get a cookie?:+
RE: DNFs at OFPR? HIJACKED
only a little there is some good info up top. its just us bottom feeders draging it down.
1 - 18 of 18 Posts
