Description: I am selling Brand New struts that I bought a few years ago when I was a DMS dealer.
Due to strong demand DMS has introduced this new product. The DMS Gold 40mm performance street range of shock absorbers.
This is a simultaneously bump/rebound adjustable shock with a wide, useable range of adjustment giving users 30 settings total. This allows adjustments and setups suited for all applications, from comfortable touring to club motor sport.
DMS Gold 40mm shock absorbers have large piston ports giving this shock superior control allowing more precise tuning.
DMS blue shell case. Made of chrome-moly high strength steel. Threaded and Fitted with screw-adjustable anodised aluminium spring seat and lock nut.
Adjustable camber available on mounting brackets using offset cam washers which prevent "camber creep".
The 40mm shock absorber also uses the famous DMS double progressive springs which provide optimum comfort as well as unsurpassed performance. All 40mm GOLD applications are availalble in MARK II valving allowing for slightly higher spring rates for autocrossers and solo enthusists alike.
These are INVERTED MONOTUBE struts, and are among the best struts you can buy for the money, period! Ask any serious rally driver.
WHAT YOU ARE BUYING:
The picture shows one front and one rear, the sale is for a complete car set of four (4) Drummond Motor Sports 40MM Gold Struts w/ springs for Subaru WRX 2002-2004 (GD Body).
These are BRAND NEW, never used, in original boxes with warranty card. Includes everything you see in the picture, including adjustment wrenches and manual.
DMS Part Number - ECS-SUB WRX(2) 40A with 225# King Double Progressive Springs up front and 180# DP spring in rear.
These have a retail price of price of more than $3000.00. My loss is your gain.
These are the street version of the same struts that many of the top rally teams worldwide use. They are designed for street and track use, and are ride height adjustable, and optimally lower vehicle approximately 1" for track use and aggresive steet driving. 40 mm pistons mean maximum control.
Please Call with all offers. I would like to get $1500 or closest offer.
For More Information Please Call 772-713-6849
Nigel
Nigel
