With the N4 cars regularly beating the Open cars (no not on all events, just on most events). It seems we should have our maximum restrictor size match Group N.
I believe Austraila has a set of rules that basically allows any or most cars to be built to Group N-type specs. Adopting and adapting the assie rules might create more competition in a top tier class.
It is my personal belief we would have better competition with fewer classes. In an ideal world I would see that as no more than 4 classes; 2 awd classes and 2 - 2wd classes. The 4 classes would be designed for Big Dollars and Small Dollars. The only wrinkle in this would be a spec class.
Our current class structure has two (sorta) dollar limited classes P and PGT. All of the other classes are Big Dollar even if you choose not to spend big $$$.
I am interested in talking the philosophy of the classes prior to naming then amd setting the rules. My suggested philosophy:
AWD - Big $$
AWD - Limited $$
2wd - Big $$
2wd - Limited $$
- I would happily substitute a Spec Class for either of the two low $$ classes.
- I would also be open to eliminating one of the low dollar classes if we could agree that either AWD or 2wd will be a run what you brung class (Big $$).
Thoughts?
Mike
AWD - Big $$
AWD - Limited $$
2wd - Big $$
2wd - Limited $$
Thoughts?
Mike
