I'm making a new passenger window out of Lexan, the alternative is buying another glass one for $300, so I thought I'd just make it my self.
I am reading in the rule book that if a lexan window is installed, it says:
'For open and group 2 vehicles, it is permissible to replace glass side windows with Lexan of like or greater thickness than the original glass. However, competitors must be able to display to the satisfaction of the event scrutineer that the mounting of the substitute windows will allow both emergency escape from inside the car and access by rescue from the outside of the car.'
I haven't molded the glass yet, but will soon. As you can see from the photo below I have no upper door frame, so I will only be attatching it to the top of the door.
http://www.dcrally.ca/lexan_slider.jpg
So a method of quick escape from inside the car is just to kick out the glass since the top and sides are basically floating other than the pressure of the bent glass.
For a solution to the "access by rescue from the outside of the car" I could just mount a small handle on the outside in which the rescuer could just pull and break off the window if need be.
Could someone fill me in on whether this is a legal way of doing it? Or if its not, could you give me an alternate solution if possible?
Thanks very much,
Thanks very much,
