1 - 20 of 25 Posts
This weekend was the RSQ AGM. There were some meeting yesterday about different aspect of the sport.
Today, at the AGM, Eric T.'s 2wd project was approved. So starting from Perce-Neige in january 2003, the "Coupe du Quebec" will now be a 2wd series only.
For 2 years, the championship eligible classes will be G2, P3, P2 and P1, for 2wd normally aspirated cars under 2000cc.
Starting in 2005, there will be only 2 classes: Production and G2 Limited. The G2 limited means limited modification to keep the cost lower. Nothing is decided yet has to what will be the limitations.
Another great news is that for Perce-Neige and Quebec, studded tires will be allowed for the Coupe du Quebec contenders (2wd cars). From what was said, maybe only one make of DOT studded tires would be approved, but I don't have infos on this one..
Also, they will try in an experimental way, to have some course note for one or two events of the Coupe du Quebec. The course notes won't be paces notes but more elaborate road book listing all the curves and some crest. But not the cut, don't cut, etc..
So that's all the info I have right now on this!!
By the way, Eric T was also elected president of RSQ with Marc Racine acting as vice-president.
Pou
so...this mean i have to run national starting from maniwaki...
i dont know....the 2wd series is a good idea...but its to bad they have to show the door to the otter car...i know they will be able to do the rally...but not be able to make some point is like a playing whit a imaginary friend.... im shure there would of been a way to do 2 championship side to side...
i just hope the national registration fees wont go up :'(
Ont va lavoire notre permis d'bières !!!!
Audi urq: Weapon!
Daman:
I'm thinking that you can still *enter* a regional rally (don't *have* to run the national event), but as you indicate, you won't score points in the coupe de Quebec.
Hovever, you *could* enter 'The 2003 Ontario-Quebec Independent Championship'...
The scoring is only based on the regional part of some national events, or some regional events themselves.
So if you have an AWD drive car in Quebec, and it fits in one of the classes that 'The 2003 Ontario-Quebec Independent Championship' supports, you can still run in Quebec regional events, with something to aim for..
Regards,
-Frank de Kat-
Yes.. ....of course we will register for that championship...no question about that....its a very cool idea...and a cool way to get people closer . we are from Hull...so rigth in the midle of the 2 province....its perfect for us....
for the 2wd championship.... i would hope for those that are not scoring point anymore that the regestration fees go down....at least ! that would be nice ? since they will be just like gost going rally to rally whit nobody keeping there points... i just think its sad to exclude people...:(
i have nothing against the mane idea... i would be more than happy to fight againts the best 2wd driver my self...one day...wen i get tired of my litle awd... but i dont like to be told what to do...or what car to by and drive...im like that what can i do....
Faster Mabricator
It seems there wasn't enough competition this year after dual National/Quebec Regional entries were prohibitted and now there will be even less. Its a good idea in concept but the low number of entries does not support it.
Too bad for Quebec regional teams like Mathieu L'Estage or Danny Bujold that just completed a 4wd car and lives in New Richmond where the Ontario championship is too far away for him to contest.
Not so bad for me. Nichols still has the VW.
What is next, banning good drivers too?
"Another great news is that for Perce-Neige and Quebec, studded tires will be allowed for the Coupe du Quebec contenders (2wd cars)."
WHOA!
The above statement can have huge implications......a studded tired car will simply be unbelievably faster than any non-studded car.
Not allowing the 4wd cars to run studs but only the 2wd cars doesn't make a lot of sense to me.........
You're punishing guys because they have 4wd.
Brian "If they allowed 4wd studs my entry would be sent in today."
Faster Mabricator
Yeah, the Regional competitors with studded tires will be passing or beating National competitors on standard winter snow or ice rallytires. Look out McGeer and Sprongl! Pierre P1 Regional competitor is in your rearview.
Brian,
You doing Open class in 2003?
The car is now in full Open class trim. It's very much like ACP's car currently.
However, which rallies I will be running is in the air currently.
I will not be running any winter events (unless I can run studs) as I simply don't enjoy them very much.
In Canada I really want to run the Western rallies but that is dependant on some sponsorship opportunities that we're attempting to secure.
I also plan on running a couple US club-rallies (on my Cd license of course) due to the 40mm restrictor rules.
Brian
1973 WRC POR
Perusse on studs in his VW? Hmmm. The organizers had better let him start as first car on the road.
Doug Woods
Discussion Starter · #11 ·
Hum.. Maybe I wasn't clear in my message. The studs are only for the Coupe du Quebec competitor. And there are no dual entries (national/regional) and no awd cars in the Coupe du Quebec standing.
I agree that the awd people registered in the regional portion of the rally won't have those studded tires and may have problems following 2wd studded cars.. And J-P Perusse won't have studded tires since he runs the national part of the rallies.
There will also be a minimum of 5 minutes between the start for the national and regional participants. The exact time will be set by the rallies from what I can tell depending on the situations. And even after reseeding, no regional can start in the national pack or vice-versa.
Pou
Faster Mabricator
There are serious saftey issues problems with that. The last National team does not have a car or sweep following them and if they go off resulting in an injury, it is 5 minutes till any form of help arrives which is probably not acceptable to the event risk management plan.
The ideal start order is always to have the regional competitors started within the National feild.
If each event were to run seperately with their own course opening and sweep for each, the organizer needs 2 opening and sweep teams, the control workers and marshalls must work much longer, National teams who've gone off may have to wait forever to retrieve their cars, and so on.
I'd prefer the same rules for everyone so that time comparisions can be made. I'd think the regional competitors would want to see how their stagetimes compared to the stagetimes same-class or similar national entries.
bite the bullet, do a stud deal with a manufactuer for all teams so it is cheap (they cannot deny that basically they will sell at least 200 of them at the rally) and we can all have fun in 'real' ice conditions !
let us run studs !
-Pat
Just because you have studs does not make your chances of crashing and damaging your car any less...i'm sure you could argue it actually increases the likelyhood of a bigger, possibly more damaging crash
There is another issue with having a five minute gap (and is one of the reasons that the SCCA went to combined start orders) and that is spectators. If there is a 5 minute gap between the last (slow) national car and the first (fast) regional car, spectators will start to move in that gap (slow car, no more coming = time to leave). Then you get the scenario where the fast regional car arrives to find spectators (who are expecting sweep or potentially a limping car) all over the road.
I would suggest a re-think of the safety implications of that concept.
>Bad example. Probably leads to worse crashes in the long
>run, but still, everywhere else uses them, and if we want to
>compete with them.....
ARE we competing with them? Who, the Swedes, the Finns? Pat R did one round in WRC and it wasn't a winter event. Who else is running studs? Who else in Canada is running European events? I find it funny, if pace/stage notes cost another $10 everybody complains about the rising costs of rallying, and if it goes up another $10 they won't be able to run the next rally. Now you're going to buy a few sets of tires to hold studs? Just being more of a Devil's advocate. I like speed too, but sometimes the logic does seem odd.
Do they run studs in the US (serious question, I didn't think they did either, but I've been wrong before!).
Craig
http://www3.sympatico.ca/kchamm/rally.html
Discussion Starter · #20 ·
Anyway, for the studded tires, we'll have to wait and see. They were talking about a one make only and Perce-Neige and quebec are coming fast.. So I don't even know if there's a deal with a tire company coming soon..
Maybe timing is too short for this, we'll see in the following weeks.
For the 5 minutes gaps, last year in Quebec, there was such a gap between the National and Regional competitors and I don't think it was that bad! What was bad was the 40 minute gap in A3 waiting for the cars stuck in A2, but that's another story!!
Pou
1 - 20 of 25 Posts
