1 - 3 of 3 Posts
stage 1 cobb tuning
one owner VIN: JF1GR89608L821772
price $18000
Miles 109000 with brand new engine .
new : short block,
new turbo(Tamioca racing TD0516G)
new head gaskets(Cometic) and ARP head studs
new oil pan and pick up tube,
new oil cooler
new water pump,oil pump and thermostat
new timing belt ,engine belt (Greddy)and hoses.
new Dunlop tires direzza
new Exedy stage 1 organic disc,ACT stret lite flywheel,
new Cobb up pipe
Perrin : cold air intake(one extra filter),turbo inlet,radiator shroud,upper radiator brakets.
Cobb : Accesport AP-SUB_003 with pre-loaded maps,turbo heat shield.
SPT : battery tie down,oil cap filler
Suspension and drive train: Perrin : rear diff bushings,shifter bushings,sub frame lock down bushings,zero lift kit,front and rear end links,front sway bar adjustable 22 mm ,rear sway bar adjustable 19 mm.
GR N : Engine mounts,pitch stop mount ,transmission mount..
Cusco: power brace steering.
SPT : front lower arm bar,strut tower brace.
GTSPEC: Rear 4 points ladder brace,power brace rear menber
Brakes: DBA 5000 front and 4000 rear
Hawk: brake pads HPS
Goodridge : stainless steel lines
Motul RBF 600 fluid.
Satellite radio with 6 CD charger Subaru sub woofer
this car is ready to go for another 20 000 miles before big service (except the engine oil every 3000)
http://www.iwsti.com/forums/used-stis-for-sale/297162-2008-sti-new-engine.html
1 - 3 of 3 Posts
