1 - 3 of 3 Posts
7,000$ for sale. Or trade for a stage rally car, that can also do Rallycross
2nd owner, car was purchased with a salvage california title due to an accident that bent the rear axle tube. Since it has been straighened and reinfoced with new axles and C clips from professional shop Dans driveline. Car was built with intent of running Just drifts limited series. Received 2nd place in a slidefactory top 16 comp. The car could be competitve in proam with more power and would probably only need a bolt on supercharger. Car can handle road courses but would need a diffrent cage to run NASA spec iron and SCCA due to the cage tube size. 1.5x.095. Cage is fully built to Formula drift requirements from Josh Mason, Pro2 Formula Drift Pro2 driver.
Car was registered and street driven to and from events in las vegas. Last event ran was in october 2018. Car ran very very well on a fast road course (pictured). since has been cleaned up and garaged waiting to be sold.
Reason for selling. No complaints of the car, very fun and rewarding to drive. I’m looking to get into rally driving
Rebuilt/Salvaged title in hand.
Engine/Trnasmission
All stock with the 4.6L V8. Coilpacks and plugs have been changed. No ticking noises or sounds of any kind. Runs very smooth. Has also a JLT intake and Bamma custom tunes. Includes a married tuner SCT X4. Tuner can be used to monitor the cars water temp, volts, ect. Never had the car run hot when driving hard in the vegas summer heat. Holly hydramat fuel pickup with hiflo pump to prevent fuel starvation/ sloshing. Transmission shifts good still also and clutch still feels good. The catch cans havent had any blow by oil built up in them from all the events the car has been used for (drifted at arund 8 events from being built). A sign of good piston rings and compression. Ford performance A/c delete kit. All of the heater and A/c components have been removed.
Exhuast
stock exhuast system. Catalytic converters have been removed, mufflers can be removed with a simple clamp. Catalytic converters would need to be installed to be registered for states that require.
Suspenion
Feal 441 coilovers, used for 4 events now. 8k front, 6k rear. front ssteering rack limiters removed for more angle. Wheel spacers all around. Fenders wells have been rolled. BMR panhard bar, with lower control arms and relocation brackets. J&M rear upper control arm. Bolt on spacers in the front, slip ons in the back. Upgraded adjustable front and rear sway bar, front one was removed for a looser rear setup. Can be put back on.
Drivetrain
Rear end has been rebuilt with new Yukon rear axles. new ford perormance 4.10 gears with welded diffrential. new c clips and reinfored axle tubes.
Brakes
Epman adjustable handbrake, full hardline setup to seprate rear caliper. New hawk perfoamnce pads.
Exterior
Stock body and paint. White stripes are faded and the rear quarter panels have small amounts of overspray from when the cage was painted. Driver rear quarter panel is also dented in from the original owners accident. I tried to straighten it as much as possible, a shop could do better. Front and rear tow hooks.
Interior
Formula drift spec built 6 point cage build by Josh Mason. Pro2 driver with Hoonigan. Racequip 4 point belts, not expired. Sparco rev driver seat. Expired. Brand new, never used XL Momo passanger seat. Sparco seat bottom mounts with side adjustments passanger and driver. Epman handbrake, Mounted fire extuingesher, mount for X4 tuner to monitor tempratures. Bluetooth stereo, rear lid speakers (doesnt sound the best but works). All sound deadening removed, interior painted. Door cards still installed and trimmed. Grip royal steering wheel with NRG quick release. Custom dead pedal.
Only word of advise for buying the car, the new momo passanger seat is so large that it sits very high and rubs on the door bars. The passanger door bar would have to be made smaller, or something so the passanger seat can sit lower. At it's current height the shoulder harness angle could compress a passangers spine.
Wheels and tires.
Has a set(4) of Rotiform wheels (pictured) and a set(4) of black STR wheels. All have tires, one pair of tires is brand new. all 235 width, great for learning. Has achilles 651s for front tires, still has lots of life. Fenders have been rolled.
Salvaged arizona title in hand
I think that covers about everything. I try to be an honest seller so if you have any questions/concerns feel free to ask. I can send videos of the car also.
1 - 3 of 3 Posts
