1 - 3 of 3 Posts
The time has come for the ford focus to find a new garage. Moved to Arizona and wanted to try out the UTV scene. Sad to see it go after all the good times had, but need to sell for new toys. This car has been very well maintained and is ready to go to the races. I raced it for one season (5 events) while I lived in Washington. The car is well sorted and is very clean.
2000 Ford Focus shell
Engine
2.0L ford Zetec DOHC
  • MSD ignition (Coil pack and wires) - April 2017 (8241)
  • Comp Cams Z281 - Severe street/competition cam shafts
  • Adjustable Cam gears
  • AEM Intake with dry flow filter
  • Top Speed intake manifold
  • competition engine mounts
  • Custom fabricated catch/vent can
-New timing Belt
-New thermostat housing
-Fresh Coolant September 2018
-Custom Support Bracket for Intake manifold Summer 2018
-Amsoil Dominator 15w-50 changed after every event, ran in conjunction with Wix filter
Electronics/Tuning
  • Custom OEM Lightened wiring Harness
  • Stock ECU chipped and tuned
Tranmission
- shortened MTX75 gear box (Mfactory 3/4/5 gears)
-Kaaz limited slip differential - August 2017
- Mfactory 4.75 final drive
-Custom breather tube with filter
- Exedy high performance sprung 4 puck clutch - Aug 2017
-Amsoil Severe Gear lube changed after every event
Exhaust
  • high flow header with heat wrap
  • 2.5" exhaust from header back
  • high flow cat
  • magnaflo high flow muffler - Nov 2016
Wheels
-6 race wheels
Tires
-Cooper Super Soft rally tires currently mounted on white wheels half life.
Brakes
  • SVT rear brake set up - new rotors/pads August 2017 (with full spares)
  • front 05 zx3 calipers and rotors - new rotors/pads August 2017 (with full spares)
  • Subaru master cylinder
Fuel system
  • Radium engineering high flow 10 micron stainless fuel filter
  • Radium engineering finned cooling system
  • braided lines
  • Aircraft grade fittings. - all of the above August 2017
Interior
  • True Steeda Short shift kit with M Factory weighted shift knob - August 2017
  • raised shifter base 5.5" for shorter wheel to shifter distance (sits like sequential shifter) - August 2017
  • Lightened Heater Box (works excellent)
  • OMP WRC winged drivers/Sparco Evo wrap around seats
  • OMP rally steering wheel
  • hydraulic hand brake (Ksport handle with new lines and upgraded Wilwood cylinder)
  • RaceQuip harnesses do expire this year and can be sent in for rebuild to be good for another 2 years.
Exterior
  • Full Underbody protection with custom countersunk mounting system (no ripping heads off)
  • Aluminum skid plate
  • carbon fiber trunk with WRC wing
  • carbon fiber hood with pod mounting hardware and hood pins
  • lexan windows with custom sliders
  • indestructible complete body kit
  • light pod set up (4 HID) (Must have for racing dark stages)
  • HID headlights
  • roof vent
Structural
  • Cage tied to Front and rear Strut Tower - reinforced August 2017
  • complete shell re-prepped and seam welded 2015
Other/misc
- newer control arms Top spec Moog (w/ full set of spares)
¬- new Moog inner and outer tie rods (with spares)
  • new steering rack including pump - April 2018
  • adjustable rear toe arms
  • relocated battery - behind driver
  • pin stands
  • several gopro mounts
Extensive Spares package
  • every available panel(hood/hatch/fenders/bumpers/doors/mirrors/headlights)
  • brand new drive shafts (both sides)
-radiator
  • brand new control arms (4 corners)
  • brand new tie rods
  • brand new ball joints
  • full brake set with multiple pads (new/used)
  • Coils/Plugs/Wires
  • Several other misc spares
Frankly, this is possibly the most over built entry/mid level rally car on the market, with a great spares package to help if you go off. There has been no expense spared on this car. The car runs top spec AMSoil fluids and has been completely gone through and extremely well maintained after each and every event. This is well sorted and log booked. Ready to go to any event.
Additional items for sale:
1 Stilo Medium helmet
1 Bell medium helmet
1 stilo 9v intercomm
Frankly, this is possibly the most over built entry/mid level rally car on the market, with a great spares package to help if you go off. There has been no expense spared on this car. The car runs top spec AMSoil*fluids*and has been completely gone through and extremely well maintained after each and every event. This is well sorted and log booked. Ready to go to any event.
Photos
https://photos.app.goo.gl/kQC3PVCgQtJGdGoD8
Priced to sell at $15,000
Call or text 970- two one nine- 44 nine 2
Engine
- MSD ignition (Coil pack and wires) - April 2017 (8241)
- Comp Cams Z281 - Severe street/competition cam shafts
- Adjustable Cam gears
- AEM Intake with dry flow filter
- Top Speed intake manifold
- competition engine mounts
- Custom fabricated catch/vent can
-New timing Belt
Electronics/Tuning
- Custom OEM Lightened wiring Harness
- Stock ECU chipped and tuned
Tranmission
Exhaust
- high flow header with heat wrap
- 2.5" exhaust from header back
- high flow cat
- magnaflo high flow muffler - Nov 2016
Wheels
-6 race wheels
Tires
Brakes
- SVT rear brake set up - new rotors/pads August 2017 (with full spares)
- front 05 zx3 calipers and rotors - new rotors/pads August 2017 (with full spares)
- Subaru master cylinder
Fuel system
- Radium engineering high flow 10 micron stainless fuel filter
- Radium engineering finned cooling system
- braided lines
- Aircraft grade fittings. - all of the above August 2017
Interior
- True Steeda Short shift kit with M Factory weighted shift knob - August 2017
- raised shifter base 5.5" for shorter wheel to shifter distance (sits like sequential shifter) - August 2017
- Lightened Heater Box (works excellent)
- OMP WRC winged drivers/Sparco Evo wrap around seats
- OMP rally steering wheel
- hydraulic hand brake (Ksport handle with new lines and upgraded Wilwood cylinder)
- RaceQuip harnesses do expire this year and can be sent in for rebuild to be good for another 2 years.
Exterior
- Full Underbody protection with custom countersunk mounting system (no ripping heads off)
- Aluminum skid plate
- carbon fiber trunk with WRC wing
- carbon fiber hood with pod mounting hardware and hood pins
- lexan windows with custom sliders
- indestructible complete body kit
- light pod set up (4 HID) (Must have for racing dark stages)
- HID headlights
- roof vent
Structural
- Cage tied to Front and rear Strut Tower - reinforced August 2017
- complete shell re-prepped and seam welded 2015
Other/misc
- new steering rack including pump - April 2018
- adjustable rear toe arms
- relocated battery - behind driver
- pin stands
- several gopro mounts
- every available panel(hood/hatch/fenders/bumpers/doors/mirrors/headlights)
- brand new drive shafts (both sides)
-radiator
- brand new control arms (4 corners)
- brand new tie rods
- brand new ball joints
- full brake set with multiple pads (new/used)
- Coils/Plugs/Wires
- Several other misc spares
Photos
Parts list sounds pretty good but for”No expense spared” You would think it would list what suspension the car has.
Especially with a 15k asking price.
1 - 3 of 3 Posts
