1992 Mazda MX-3 GS - Located in Simi Valley, CA
Log booked and 100% ready to race
$7,000
Brian - 805-229-1239
SOLD
Last raced at the end of August
Very easy to drive car, rotates effortlessly. Great car for a beginner that has plenty of room to grow as a driver.
Drivetrain / Enginebay
Exterior
Suspension
Brakes
Interior
Misc
Spare parts
$7,000
SOLD
- 2.5L KLZE V6 (200HP, 8500RPM redline)
- G4 intake / KL47 ported throttle body
- OBD2 conversion
- MAF/IAT conversion (with custom brace)
- External coil / HEI ignition conversion
- Long tube headers
- Wideband O2
- Holly Hydromat fuel pickup
- Walbro 255 external fuel pump
- 5-speed with Mazdaspeed LSD
- Oversized Griffin aluminum radiator
- Dual electric fans with temp switch and override switches
- Battery jumper / distribution posts
- Hella Horns
- Poly motor mount
- Oversized power steering reservoir
Exterior
- LED headlights in projector housings
- OEM GT500 hood vent
- Quick removable lightbar with 2x yellow halogen projectors, 2x HID corner lights, 1x LED lightbar
- Rallyarmor mudflaps
Suspension
- HotBits with external reservoirs (fully rebuilt 1 race ago)
- Fully adjustable camber and caster front top mounts, camber only in the rear
- 1/8 steel plated front shock towers
- Plated rear shock towers
- Adjustable limiting straps
- Fully custom rear suspension
- All 1.5" DOM, 1/4" wall tubing
- 1/8" double sheer plates
- Greaseable joints
- Adjustable toe
Brakes
- Manual brake conversion
- Upgraded rear brakes to disc
- Rear lines routed through interior
- Porterfield racing pads all around
- Wilwood hydraulic handbrake
- Rear brake line shut-off valve
Interior
- Cobra Monaco Pro seats
- Relocated windshield wiper fluid reservoir
- Relocated battery behind seats
- Powersport AGM battery
- Custom impact gun mount
- Custom scissor jack mount
- Ammocan toolbox
- Front red LED cab lighting
- Rear white LED trunk lighting
- LED adjustable co-driver light
- Dual USB ports for tablet or GoPro charging
- Fuel pump, fan, acc, USB override switches
- Wideband O2 gauge
- Power windows
- Front electric windshield defroster
- Custom bluetooth tablet gauge cluster with multiple modes (race, recce, street)
- Battery cutoff switch
- Spill-kit
- First aid kit
- Helmet hammock
- Fire extinguishers with aluminum quick release
- Driver / co-driver bags for storage
- Window breakers / belt cutters
- NRG quick release hub
- Sparco steering wheel
- Roof scoop with adjustable vents
- Reduced and removed all unneeded factory wiring, rear wiper motor, etc.
- Cup holder
Misc
- New paint a couple months ago
- 15" Protege wheels with Federal rally tires
- Spare MX-3 wheels with spare rally tires
- Full-size 1/4" aluminum skid plate
- Quick plug for battery charger
Spare parts
- Fan shroud and fans
- Axles
- Brake pads
- Taillights
- Engine (for parts or rebuild)
- Transmission
- Bumpers (front and rear)
- Rear hatch (with glass intact)
- Fuse boxes, wire harness
- Factory gauge clusters
- Original ECU and VAF setup
- Brake master and reservoir
- New tie rods, ball joints, wheel spacers
- New steering rack
- Drivers side door
