1 - 2 of 2 Posts
$20,000. Deal of the century. Get this car outta my garage and go racing tomorrow. Logbooked and raced in Super-production in Rally America national class. Car is in great shape and needs nothing to go racing right now. Acid dipped shell. Custom cages homolgated cage. Carbon-kevlar underbody protection (with 2 spare side panels) from Rally Spares. Primitive Racing diff shield. Custom engine skidplate and mounting brace. Custom lightpod set-up. Peltor intercom, Cobra evolution pro seats. Schroth belts good through 2018. Sparco helmet box. Navigator light. Teratrip rally computer (uninstalled). Full HD camera system (uninstalled). Custom brake lines. Hydraulic handbrake. RS/SP shocks on rear. Ohlins shocks on front (also have/including both rears) 5 gold Speedline rims. 4 white Team Dynamic rims. 13 Pirelli medium compound tires (2 brand new, 11 nearly new). 16 Lassa tires ( 10 in good stage worthy shape, 6 worn but still good for practice). AP Racing gravel brakes.
Engine: OEM rebuilt with 1 race on it. 701 casing halves. OEM rods/pistons/valves/cams. OEM nitrated crank. D25C heads. King STD X bearings. New VF43 turbo with 1 race on it. Bosch .044 fuel pump. V88 Vipec with anti-lag and launch control enabled. Also including a mini laptop with case for the tuner!
Many spares: Front crossmember, differential front member, intercooler, intercooler Y pipe, 2 radiator fans, brake fluid reservoir unit, front & rear bearings, 3 control arms, 7 front lateral links, 6 rear lateral links, 4 strut mounts, 2 fronts struts & coil overs, 2 rear struts & coil overs, VF 43 turbo, propeller shaft assembly, rear drive shaft assembly, 2 rear spindles, drive shaft assembly front, 2 front spindles, tie rod end assembly, stabilizer link, ball joint, 2 front brake lines, rear brake line, 2 alternators, alternator belt, Koyorad aluminum radiator, radiator hose inlet & outlet, 2 left side doors (drivers & rear), 3 wheel scrapers, 3 windshield wiper blades, air filter, roll cage padding, 3 gallons Rotella motor oil, gallon coolant. $20,000 for car and all spares. Located in Charleston, South Carolina. Pictures are on my facebook page: Belmont Motoring. Contact me at (760) 213-7356
1 - 2 of 2 Posts
