Got my feet wet with my VW but I felt it was time to move on to something else. I wanted to go with a Honda for a while. After searching around I got myself an 1996 EK hatch with a B16A2 swap from a 1999 Civic Si from a local guy. I am building this car for stage rally first, but I am going to try to mee H1/H2 Honda Challenge rules so I can do road races at Mid-Ohio if I want.
Goal right now is to get out on the stages first and then slowly upgrade/replace parts as I go along. I'm probably going to get sucked into building a super car, but that's way beyond my budget. I want to make the car drivable/presentable for track day testing with rally debut for at LSPR for MaxAttack! in October.
I'll do my best to keep updates on this and index everything on this first post so people can do a quick reference.
So let the build begin!!!
Table of Contents:
The car, and tearing out interior. Post 2
Tearing out more interior w/ HVAC removal. Cage feet cleaning and glass removal. Engine shot.Post 21
Ghetto cruiser! Post 22
Partial cage install. Post 30
Cage finished and underside of car shots. Post 36
Removal of tea cup saucer brakes. Post 37
Declutter of rear hatch wiring. Post 68
Pulling of motor, brake master/booster, clutch master. Post 84.
Stitch welding interior, dash mounts, pedal box mounts, filled motor mounts, rotisserie, hydro handbrake. Post 91
Haven't been in a rally, but I got the car on its roof already... Post 93
Finished stitch welding and pin jack stands Post 99
Epoxy underside, starting interior painting, painted engine bay, front bracing, pin jack.s Post 106
Interior painting, sway bar mounts, fuel/brake lines, interior dash wiring. Post 187
Transmission work. Post 188
Suspension/Brakes. Post 189
Rear Skidplate fabrication @ TRF and glimpses of underbody HDPE. Post 190
Cleaning of the washer reservoir/pumps. Post 197
Underbody and battery tray. Post 211
Table of Contents:
