2005 STi, White, with a bad engine
Results 1 to 4 of 4
Thread: 2005 STi, White, with a bad engine
    Default 2005 STi, White, with a bad engine
    Year, Make, Model: 2005 Subaru Impreza WRX STi
    Price: $7,777.77
    Mileage: 192,200
    Transmission: 2005 STi 6 speed
    Description and Mods: See below.
    Mechanic's Special:
    Up for sale is my 2005 STi.
    THE GOOD:
    2 Owner Car since new, both adults
    Car has been taken care of, hence 192,200 original miles on original engine, original turbo.
    This is a clean NC car, no rust.
    Interior
    Professionally tinted windows, legal for NC (>35%)
    Original Alcantara STi seats, black and blue, front and rear
    Engine
    2.5L Subaru EJ257 Boxer Engine
    #4 cylinder misfire
    Killer B Motorsport Aluminum Oil Pan Package
    Torque Solution Engine Mounts: Subaru Wrx Sti 2002-2016
    Brakes
    Ferodo DS 2500 Brake Pads, front and rear on
    DB Rotors
    Goodridge SS Brake Lines
    ATE Type 200 Brake Fluid
    Electrical
    Odyssey PC680-P Battery
    Kartboy Battery tie down
    Steering
    STI JDM GROUP N POWER STEERING COOLER
    STi Power Steering Pump and hoses replaced in 2018
    Exterior
    04 05 Aftermarket Made SUBARU IMPREZA WRX SPORT STi Front PU Bumper Lip
    (5) Perrin Wing Stiffies, Black
    Gurney Flap for 2003 BMW M5 on top of STi Factory Wing
    Suspension
    2005 STi Feal Revalved Tarmac Struts
    Group N Strut Top Mounts, front and rear
    Whiteline Front Sway Bar 24mm Adjustable
    Whiteline Rear Sway Bar 24mm Adjustable
    Whiteline 24mm Sway Bar Aluminum Lateral Lock Kit
    Kartboy Whiteline Front Swaybar Spacers
    Whiteline Front Endlinks Sedan
    Whiteline Anti Lift Kit Race Version
    Kartboy Transmission Crossmember Bushings-
    Torque Solution Billet Aluminum Pitch Stop Tranny Mount (Black): Subaru
    Drivetrain
    6 speed Subaru tranmission
    R180 Rear Diff
    Factory DCCD
    Exhaust
    COBB Catted Downpipe
    GrimmSpeed 3in Downpipe to Stock Cat-Back Adapter
    GrimmSpeed Turbo to Downpipe Gasket
    STi Genome Axle-back Muffler
    Tires and Wheels
    2005 STi BBS Wheels 17x8" 5x114.3, Silver
    Hankook WinterCept Evo2 245/45R17 Snow Tires
    16mm spacers in front
    5mm spacers in rear
    ARP 3" Extended Lugs
    The Bad:
    Engine is running on 3 cylinders
    Cylinder 4 misfire code
    Compression / Leakdown numbers (at 100psi for leakdown):
    Cylinder 1: 139/97 psi
    Cylinder 2: 137/96 psi
    Cylinder 3: 132/94 psi
    Cylinder 4: 126/88 psi
    The driver's door and mirror are damaged, neighbor backed into the car when parked.
    The front bumper is skewed slightly because when I moved, the Penske trailer I rented had a lip at the front, the car drove on fine but when I backed off of the trailer, the bumper snagged on the trailer lip and pulled off.
    There is no trunk carpet. The factory front undertray is missing, I ran a Primitive Racing 3/16" aluminum skidplate the entire time, that skidplate will not come with the car.
    There is a ding / scratch on the hood. Someone threw or dropped a rock on the hood when it was parked.
    This is a rust free example of a 2005 STi. It has been taken care of, but shows normal wear and tear on a 15 year old car. This car has not been offroad and is very clean underneath.
    The gauge pod on the dash was a factory option, but the oil temp sensor is pretty worn out and I never got around to replacing it, so the gauge sporadically works. I can't think of any other issues with this car that is not listed.
    Everything else on this car works.
    Please let me know if you have questions or want to see anything in particular, virtually.
    This is a link to my ebay auction:
    https://www.ebay.com/itm/184455929289
