Year, Make, Model: 2005 Subaru Impreza WRX STi
Price: $7,777.77
Mileage: 192,200
Transmission: 2005 STi 6 speed
Description and Mods: See below.
Mechanic's Special:
Up for sale is my 2005 STi.
THE GOOD:
2 Owner Car since new, both adults
Car has been taken care of, hence 192,200 original miles on original engine, original turbo.
This is a clean NC car, no rust.
Interior
Professionally tinted windows, legal for NC (>35%)
Original Alcantara STi seats, black and blue, front and rear
Engine
2.5L Subaru EJ257 Boxer Engine
#4 cylinder misfire
Killer B Motorsport Aluminum Oil Pan Package
Torque Solution Engine Mounts: Subaru Wrx Sti 2002-2016
Brakes
Ferodo DS 2500 Brake Pads, front and rear on
DB Rotors
Goodridge SS Brake Lines
ATE Type 200 Brake Fluid
Electrical
Odyssey PC680-P Battery
Kartboy Battery tie down
Steering
STI JDM GROUP N POWER STEERING COOLER
STi Power Steering Pump and hoses replaced in 2018
Exterior
04 05 Aftermarket Made SUBARU IMPREZA WRX SPORT STi Front PU Bumper Lip
(5) Perrin Wing Stiffies, Black
Gurney Flap for 2003 BMW M5 on top of STi Factory Wing
Suspension
2005 STi Feal Revalved Tarmac Struts
Group N Strut Top Mounts, front and rear
Whiteline Front Sway Bar 24mm Adjustable
Whiteline Rear Sway Bar 24mm Adjustable
Whiteline 24mm Sway Bar Aluminum Lateral Lock Kit
Kartboy Whiteline Front Swaybar Spacers
Whiteline Front Endlinks Sedan
Whiteline Anti Lift Kit Race Version
Kartboy Transmission Crossmember Bushings-
Torque Solution Billet Aluminum Pitch Stop Tranny Mount (Black): Subaru
Exhaust
COBB Catted Downpipe
GrimmSpeed 3in Downpipe to Stock Cat-Back Adapter
GrimmSpeed Turbo to Downpipe Gasket
STi Genome Axle-back Muffler
Tires and Wheels
2005 STi BBS Wheels 17x8" 5x114.3, Silver
Hankook WinterCept Evo2 245/45R17 Snow Tires
16mm spacers in front
5mm spacers in rear
ARP 3" Extended Lugs
The Bad:
Engine is running on 3 cylinders
Cylinder 4 misfire code
Compression / Leakdown numbers (at 100psi for leakdown):
Cylinder 1: 139/97 psi
Cylinder 2: 137/96 psi
Cylinder 3: 132/94 psi
Cylinder 4: 126/88 psi
The driver's door and mirror are damaged, neighbor backed into the car when parked.
The front bumper is skewed slightly because when I moved, the Penske trailer I rented had a lip at the front, the car drove on fine but when I backed off of the trailer, the bumper snagged on the trailer lip and pulled off.
There is no trunk carpet. The factory front undertray is missing, I ran a Primitive Racing 3/16" aluminum skidplate the entire time, that skidplate will not come with the car.
There is a ding / scratch on the hood. Someone threw or dropped a rock on the hood when it was parked.
This is a rust free example of a 2005 STi. It has been taken care of, but shows normal wear and tear on a 15 year old car. This car has not been offroad and is very clean underneath.
The gauge pod on the dash was a factory option, but the oil temp sensor is pretty worn out and I never got around to replacing it, so the gauge sporadically works. I can't think of any other issues with this car that is not listed.
Everything else on this car works.
Please let me know if you have questions or want to see anything in particular, virtually.
