93 Honda Civic Hatch
2wd open class car in ARA, or light in NASA. Car is highly competitive and was running top 10 at SOFR, 2nd behind Hooper giving him a run for his money. I’m selling because it’s just too much stress and time on the family to try and race at national level.
$12000 OBO
Chassis
• Rally America Log Booked with over built cage
• OMP RSPT Driver Seat
• Racetech passenger seat
• G Force 5 point belts good through 2019
• ½ inch think front skid plate
• Radiator raised 2 inches with 0.120 steel subframe and skidplate mount
• Howe 2 to 1 steering quickener
Suspension
• Bilstein HD Shocks relvave by RE Suspension. Droop limiters removed
• 8 inches of travel front
• 7 inches of travel rear
• 19 mm front sway bar
• JDM 29 mm rear bar
• Swift Springs front/rear with ride frequencys 1.5/1.6 hz
• Poly bushings rear
• Brand New Hardrace front bushings
Engine
• B20 Vtec with GSR head (2.0L with 14:1 compression)
• Crankshaft polished balance with sludge balls removed
• Block bored to 84.5 mm
• ACL high flow oil pump
• SCAT rods
• HAS sport 90 da motor mounts
• Nippon Racing P30 pistons
• Skunk 2 Pro 2 cams, with XP springs, and skunk titanium retainers
• Dodge viper oil to water cooler
• Mishimoto 70 C thermostat
• HAmotorsports ECU with Hondata S300 (new fall of 2018)
• AEM 320 lph fuel pump
• Fuel Injector Clinic 650 injectors (new spring of 2019)
• Current rev limiter is 8600, but engine is good to 9400 rpm. I built for reliability, engine has 2 rallys, a couple of rally cross’s and a high climb on it. Burns absolutely no oil. Uses 0w40 Mobil 1. Runs on E85.
Transmission
• GSR with 2 year old synchros
• Integra Type R helical LSD
• B16 3rd and 4th gears for closer ratio 2,3,4
• 4.44 stock final drive ratio
• Drive shaft shop 2.9 axles
Tires
• 6- maxxis r19 softs on BMW basket weaves
• 4- Silverstone softs on BMW bottle caps (bent/slow leaks but work for rally cross)
Spares
• Controls arms front and rear
• Softer rear bar
• Assorted 2.5 inch springs
