Status
Not open for further replies.
'02 Focus, fully built, gravel or tarmac
11K views 9 replies 4 participants last post by  rallyxr4ti
#1 · (Edited)
Wheel Car Tire Vehicle Land vehicle
Wheel Tire Vehicle registration plate Car Vehicle
Wheel Tire Automotive parking light Land vehicle Automotive side marker light
Automotive parking light Automotive lighting Automotive tail & brake light Hood Grille
Car Vehicle Hood Motor vehicle Automotive design
Automotive tire Motor vehicle Automotive fuel system Vehicle Coil spring
Vehicle Car Hood Motor vehicle Automotive lighting
Vehicle Car Motor vehicle Automotive design Automotive tire
Car Vehicle Motor vehicle Hood Automotive tire
Wheel Tire Vehicle Car Hood
Car Vehicle Plant Wheel Tire
Automotive fuel system Automotive air manifold Motor vehicle Gas Nut
Wheel Tire Car Vehicle Hood
https://www.flickr.com/photos/170255247@N08/with/40928951903/
'02 SVT Focus originally built for "Spec Focus Rally"
I have owned it for the last 10 years. I have records of almost all the purchases and a log of events. I have used it several times in the last few years it preformed very well and I had no issues with it. I am selling because my wife and I now have 3 little kids and this car is no longer my priority. I am sorry to see the car go but we could use the money more than a perfectly good race car collecting dust in the garage.
Duratec 2.3
handmade int/exh manifolds
Block: 2.3L Duratec Stock 87.5mm Bore
Crank: 2.3L Duratec Ranger, 94mm stroke
Rods: Eagle H-Beam 6.094"
Pistons: 13.0:1 compression Supertech Forgings
Camshafts: Crane Cams Stage 4, 224-0016
Oil Pan: Modified Stock
3" exhaust
240whp on conservative tune and conservative dyno
5 speed MTX75 gearbox
rebuilt with gearset from Mk1 Focus RS
final drive lowered to 4.5:1
Torsen ATB diff
Cosworth flywheel
Clutchmasters stage 4 clutch
short shifter on raised pedestal
Drummond Motorsport coilovers - springs for gravel or tarmac
these coilovers are super beefy 50mm items with an inverted damper setup, over $5k new
all tubular control arms and poly bushes
setup can easily be changed from tarmac to gravel, tarmac setup is great on road courses
upgraded power steering pump, ratio quickener, and small diameter sparco wheel
1552 Tarmacs, Rotas, Team Dynamics gravel wheels
NASA logged cage, custom built
racetech seats
transponder
terratrip intercom
terratrip "rally computer" odometer
roof scoop and bonnet vents molded off WRC car parts - and function
rally light pod
very stout full underbody protection
spare parts
will include helmets and neck restraint device
current non-op registration
This car is well sorted out and ready to go.
For rally, this car fits in the Limited 2wd class, but is as fast as the open 2wd cars. It would be very competitive in time attack.
$15,000 firm
I would like to sell it with our car trailer. It is a ~7yr old Big Tex single car trailer. upgraded to have brakes on both axles. newer tires. long ramps for lowered cars. good cond. additional $1,500
PM me for details or email: rallyfocusforsale@gmail.com
See less See more
13
#7 · (Edited)
try agian for pics
Status
You have insufficient privileges to reply here.
