Coil spring suspension companies?
Results 1 to 8 of 8
Thread: Coil spring suspension companies?
    Default Coil spring suspension companies?
    Hello! I’m building a 2005 Mustang GT for Rallycross and I want to lift it. Currently I’m going to be getting a set of Bilstein hd front struts and rear shocks. I’m looking for a good company to make some that can make longer shocks for Rallycross and I’ll be using the car for stage rally in the future
    100 K right 2 Perry's Avatar
    Nov 2011
    Pittsburgh, PA United States
    80
    That's strut in the front right?
    Generally this means getting the universal Bilstein rally strut and adapting it for your use. Unless there's a rally strut available already. Maybe look at hotbits of they are still around.
    For now (rallycross) you could put coilover sleeves on the Bilstein HDs and buy 2.5 inch race springs in the rate of your choosing. Then set the ride height you need.
    Or just run it with stock parts. Rallycross usually isn't all that rough around here.
    For rallycross you will probably be good with bilsteins and stock springs. Maybe some spacers to add a little lift if needed.
    Otherwise you will probably be going full custom built struts like Perry mentioned.
    Check with Maximum Motorsports. They helped with my 1995 Mustang.
    200 square left
    Dec 2002
    Simi Valley, California, USA.
    184
    I used these guys for the front struts on my focus.
    Not coilover.
    I wanted taller firmer springs to go on my stock hats.
    Told them how much lift and how much firmer I wanted.
    http://www.coilsprings.com/
    They worked out perfectly and not expensive and came quickly.
    Support your Local North American Rally Forum!!
    While they are still around-and get the hell off Farsebook!!
    We still have Specialstage & RallyAnarchy.
    Post up Here:
    https://rallyanarchy.com/phorum/posting.php
    and here:
    https://www.specialstage.com/forums/forum.php
  8. #6
    200 square left
    Dec 2002
    184
    Here is the quote Page where they ask you the info they want to know when you’re ordering springs:
    http://www.coilsprings.com/request_q...px?type=sports
    Post up Here:
    and here:
  9. #7
    Quote Originally Posted by rallyxr4ti View Post
    Not coilover.
    Yes Sir. I based my Poor-Man's coilovers off your custom spring info. You said 175lb worked well on your Focus, so I use 175lb Eibach Coils on my SVT Struts. Worked Perfect
  10. #8
    200 square left
    Dec 2002
    184
    Quote Originally Posted by DirtyDave View Post
    Not coilover.
    Oh that’s cool. Glad it worked out for you. Yeah I saw your coil overs over at FF- they look good.
    Hopefully one of these days I have that damn car moving under its own power again!
    Post up Here:
    and here:
