2002 WRX with lots of extras
$9500
135000 miles
List of Modifications:
APS dual ball bearing turbo
APS front mount intercooler
COBB blow off valve
APS tumbler delete/aux injector manifold housing
APS cold air intake with K&N air filter
GrimmSpeed electronic boost controller
GrimmSpeed catless up-pipe
255 Walbro fuel pump
STI injectors
STI engine and transmission mounts
Maddad catless down-pipe
Invida N1 Street 3 inch exhaust
Perrin Turbo inlet
Rebuilt 5 speed manual transmission with RA gear set (new clutch at the same time)
KW coilovers (included, currently sitting on stock WRX shocks and struts)
Morette headlights
Dash tripple gauge cluster (Boost, oil preasure, oil temperature)
AFR gauge mounted in glovebox
New infinity front and JBL rear speakers
COBB shift knob
Also included:
SPT short ram intake
KW coilovers
STI lateral end links
STI rear sway bar
COBB Access port with 3 maps
Yakima snowboard and bike roof rack
Extra set of summer tires
It was tuned last year by Surgeline to run very conservatively and made 280 whp at 18lbs of boost. With a more aggressive tune it is capable of making 400hp. Timing belt, water pump, MAF, and radiator replaced as well as a ton of other maintenance. Have all receipts and records for the car as well. The car competed in Oregon Rally Group and Northwest RallyX races in Modified and Prepared AWD class all last year with no issues.
*No Trades please
a1fbdc828d6be68c7d32a2050e4e1671.jpg[/IMG]
Sent from my iPhone using Tapatalk
$9500
135000 miles
COBB blow off valve
STI injectors
Perrin Turbo inlet
Morette headlights
COBB shift knob
Also included:
KW coilovers
STI rear sway bar
*No Trades please
