Footwell LED Kit! RGB Multicolor & Single color kits! Perfect Cage Lighting!
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Footwell LED Kit! RGB Multicolor & Single color kits! Perfect Cage Lighting!
    Default Footwell LED Kit! RGB Multicolor & Single color kits! Perfect Cage Lighting!
    Looking to add visibility to your rally car's interior? Our Footwell LED kits are the easy way to do it! By adding bright LED strips under your dash or on your cage, you can add useful brightness to your rally car.
    Diode Dynamics has been producing and designing easy-to-install LED kits for nearly a decade, and this kit is no exception. We have designed new LED strips to be used in this kit, which are highly flexible, waterproof, and long-lasting. This kit also has RGB Multicolor options, which are controlled by remote! You can change the color to fit your needs, or adjust the brightness to your preferred settings.
    Included in the kit:
    • 2 (two) 30-5050 SMD Strips (flexible and IP67 waterproof)
    • Wiring harness for easy installation
    • 2 (two) quick-splices for installation
    • LED Toggle switch in your choice of LED color
    • RGB Controller Box with RF sensor and 4 outputs
    • Remote Control (choose Standard or upgrade to Bluetooth or WiFi)
    • 4 (four) zip-ties and 3M outdoor adhesive pads for mounting strips
    • Three-year Diode Dynamics worry-free limited warranty
    • 30-day satisfaction guarantee
    Also included with rear footwell option:
    • 2 (two) additional 30-5050 SMD Strips (flexible and waterproof)
    • 2 (two) 3-meter (ten-foot) extension wires
    • Additional zip-ties and adhesive pads
    Any questions email us at [email protected] or call: (314) 205-3033
    *PM us for the free-shipping code* (U.S. forum members only)
    Thanks!
    Nick C.
    https://i.imgur.com/jpbgbzt.jpg
    http://www.youtube.com/watch?v=gQ0QJ8EN__U
    How to Set Up and Troubleshoot RGB Controllers | Diode Dynamics
    RGB Footwell and Grille Lighting Kit shown on our 2016 F-150 SEMA Build
    Diode Dynamics Multi-color Grille LED Kit installed!
    2018 Jeep Grand Cherokee Trackhawk RGB Lighting Upgrades by Diode Dynamics
