WTB VW 020 16V 3.94 or 4.20 Ring&Pinion
Results 1 to 10 of 10
Thread: WTB VW 020 16V 3.94 or 4.20 Ring&Pinion
    100 K left 2
    Jul 2015
    Fork Lake, AB
    8
    Default WTB VW 020 16V 3.94 or 4.20 Ring&Pinion
    Needs to be 16V as the 4th gear spline diameter is different on the 8V stuff.
    Thanks in advance.
    I think you'll have better luck on the VWvortex classifieds. Check out the MK2 classifieds and engine transmission classifieds below
    http://forums.vwvortex.com/forumdisp...on-Classifieds
    100 K left 2
    Jul 2015
    Fork Lake, AB
    8
    Anyone, leads appreciated and will be followed up on!
    100 oversquare right bentmettle's Avatar
    Dec 2004
    Ann Arbor, Michigan
    3,471
    http://www.ebay.co.uk/sch/i.html?_fr...wheel&_sacat=0
    easier to install the 4th gear from an 8V than chase the 16V specific pinion probably.
    100 K left 2
    Jul 2015
    Fork Lake, AB
    8
    Quote Originally Posted by bentmettle View Post
    I have a 1.43 4th so would have to be a super expensive custom gear and then I'd have a R&P that isn't nearly as strong as the motorsports stuff.
  8. #6
    100 K left 2
    Oct 2015
    USA, Binghamton NY
    30
    What's the project?
  9. #7
    Dec 2004
    Ann Arbor, Michigan
    3,471
    Sorry, figured you were working on a rally car.
    I gave up on the 020 after our Hoer R&P died in 2012 or whenever it was.
  10. #8
    100 K left 2
    Jul 2015
    Fork Lake, AB
    8
    Quote Originally Posted by DawsonE30 View Post
    What's the project?
    Mk2 for Stage Rally. Have a VWMS 16V gearset so need the 16V ring and pinion.
  11. #9
    100 K left 2
    Jul 2015
    Fork Lake, AB
    8
    I am, not sure what you mean by that. The 020 is plenty strong if its built right. And by built right I don't mean stock internals with some crazy high undercut pinion like a 4.8 or 5.07.
  12. #10
    100 K left 2
    Jul 2015
    Fork Lake, AB
    8
    Bump!
