Mini Cooper to compete at Sno*Drift 2013
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Mini Cooper to compete at Sno*Drift 2013
    It is Flat on the Floor!! Davenport576's Avatar
    Princeton, MN, USA.
    275
    Default Mini Cooper to compete at Sno*Drift 2013
    Hey!! Davenport Racing will be at Sno*Drift 2013 supporting Markus Saarinen in his 2003 Mini Cooper! The Mini Cooper will be in Group 2 and is not stock. NA engine massaged for more up and torque. 6spd transmission. Beautiful lexan windows, Braid wheels, carbon light pod with KC HiLite 70 watt hid lights and a very nice custom set of radial mount Wilwood calipers and slotted rotors. Should be exciting.
    Come out and cheer us on in Markus Saarinen's first rally!!
    Rally car build by Davenport Racing!
    Engine and trans work by Madness Motorworks!
    www.davenportracingusa.com
    You get one life,live it! ugly's Avatar
    El Coyol, Costa Rica, Upton,MA,USA
    1,911
    Looking forward to seeing another Mini out there.
    Cheers,
    Chris
    Rally Mini Cooper JCW #37: Sponsors EBC brakes,Muflas Sicar,Fortech CR, G oil CR, Minigearboxes UK
    Respectognize! Whizbang's Avatar
    Mar 2011
    Santa Rosa, CA
    143
    ill be curious to see how it does!
    For current updates and event coverage check out
    Follow on Twitter! @WhizbangRally
    Whizbang Rally's Webpage | Facebook
    1,911
    Me too! I figure the gearing would be a little tall for a NA engine and maybe a ground clearance issue....but if there is snow that won't be an issue.
    Cheers,
    Chris
    1,911
    How did the Mini do?
    Cheers,
    Chris
    just another old phart Foghorn's Avatar
    Toledo, Ohio, USA.
    2,258
    I only saw it from the perspective of working starts and finishes. I don't recall seeing it the first day but on the second day they seemed to be well under control for the conditions and doing nicely for first time entrants.
    Kent Gardam - KD8MRR
    this is rally, and it's not supposed to be easy....Eric Burmeister, 2009
    In my opinion, rallying could stand a bit less posturing and circus and a bit more backbone....Phil Barnes, aging co-driver
    Foolish NBS2005's Avatar
    Nov 2004
    Toronto ON, Canada
    122
    What are they running for suspension?
    Fortune Favour the Foolish RallySport
    Toronto, ON Canada
    rallyfools AT gmail DOT com
    Princeton, MN, USA.
    275
    The Mini had Hotbits with bump and rebound adjustment wn spherical top mounts. Fronts have camber adjustment.
    1,911
    PM me his contact info, it would be nice to know of any issues they had.
    Cheers,
    Chris
    Princeton, MN, USA.
    275
    There were no big issues. Both driver and co-driver are new so that was a bit. Car set up was bit off but came around on the second day. 100a should be better as long as it stays dry! From that point toward we have looked at a different final drive but not sure at this time. The future may involve a turbo or supercharger and may wait till then on a gears or final drive option.
Tags for this Thread
