Subaru WRX TD04 turbo's with restrictors
Results 1 to 2 of 2
Thread: Subaru WRX TD04 turbo's with restrictors
    "Go fast then bah bah bah"
    Nashua, New Hampshire, USA.
    222
    Default Subaru WRX TD04 turbo's with restrictors
    We are selling 2 stock Subaru WRX TD04 turbo's with milled cold side intakes and safety wired 34mm restrictors installed.
    The first turbo has a Prodrive restrictor, only 2300 miles on it with no shaft play (either side to side or in/out). Both the cold side intake and the restrictor where machined to fit together. The Prodrive restrictor tapers up to 34mm in the middle of the body and then tapers out.
    http://www.flickr.com/photos/[email protected]/8176410039/
    http://www.flickr.com/photos/8994442...n/photostream/
    The other TD04 turbo has a Rallispec restrictor, with only 1750 miles on it. There is no end-to-end or side to side shaft play and the cold side intake has been machined to receive the restrictor.
    Asking $300 each plus shipping.
    -Tim
    Wazoo Racing
    tim at wazooracing dot com
    Wiling to separate just the resctrictor from one??
Tags for this Thread
