Peltor G79
Results 1 to 2 of 2
Thread: Peltor G79
    Rallysport.ca Calgary, Albert Shawn's Avatar
    Calgary, Alberta, Canada.
    803
    Default Peltor G79
    The G79 continues the iconic Peltor™ rally helmet legacy.
    The helmet has built in hearing protector cups that attenuate ambient noise, which improves communication and comfort.
    Available with and without communication kit.
    Key Features:
    • Adjustable peak with sun visor
    • Noise cancelling microphone
    • Quick positioning integrated microphone boom
    • Built in hearing protector cups
    • H.A.N.S® post anchors
    • SNELL SA2010
    • FIA8858-2010
    • Compatible with Peltor™ FMT111, FMT120, FMT200, DectCom II, and FL50**- series adapters
    Materials:
    Shell: Tri-weave. (Kevlar®/Carbon Fiber/Fiberglass composite)
    Liner: EPS (expanded polystyrene)
    Padding: Nomex®, PU foam
    Chin Strap: Kevlar®
    Standards and Approval:
    The G79 series helmets are tested and certified under the SNELL SA2010 standard.
    FIA8858-2010 approved for use with HANS device.
    Peltor G79 is available in the following sizes, please specify size when ordering:
    G79S-D VI, comm. Small (56-57cm) white (Special Order)
    G79M-D VI, comm. Medium (58-59cm) white
    G79L-D VI, comm. Large (60cm) white
    G79XL-D VI, comm. Extra Large (61cm) white
    Data Sheet
    http://rallysport.ca/files/3M_Motorsport_2012.pdf
    Look me up
    Shawn
    -- Shawn Bishop
    RALLYSPORT.CA
    403.277.6291 | shawn (at) rallysport.ca
    Everything You Need to GO Rallying!
    Hans Device | Piaa and Wolf Lighting | Peltor & Stilo |Rally Computers | Codrivers | Drift Cameras
    Getting Started Guide
    Twitter | Facebook
    803
    We have some of the G79 in stock and available. Introductory price of $849 cdn (MSRP $979)
    Also with the update to the CARS regulations, there is a limited number of G78 helmets available at much reduced prices. (only a few XL/grey left)
    Shawn
    -- Shawn Bishop
    RALLYSPORT.CA
    Twitter | Facebook
