Need help choosing Gravel Suspension for GC impreza
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Need help choosing Gravel Suspension for GC impreza
    Default ...........
    TG Dog/dogbox /LSD for any car ktibi's Avatar
    Dec 2004
    Calgary,Wild Rose Country
    585
    I can give you 1 set for free(shipping only), for 1 event. If you don't like it return it. If you like it will cost you 1800 $ + shipping.Brand new never used, choice of spring rates!
    Won stages with it, on regional event. Tested at PFR.
    45mm bilstein licenced fully adjustable(hight/bump/rebound) rebuildable 11.5 inch progressive springs with 8 inch stroke.
    the best? NO! Can you win a rally with it? Yes! Will hold for a season? Yes!(if you maintain it) Cost? Can't beat it.
    RS&SP entry level set ~3000 grand, 1 competitor is using it, and he dose not like it a lot
    pro level set ~6000 grand Very good 2 cars using it on the west championship
    Hot bits , you get what you pay for. Maybe the new version is good.
    There is a lot out on the market, look around.
    with Proflex/Ohlins, you wont go wrong
    rookie forevo
    Hi Mark,
    I ran the original DT1 hotbits and while they work great for "slower" cars that don't pound on things so hard, once you get into open class speeds they just can't take the abuse. I've bent or exploded all four of them, unfortunately.
    Before Tall Pines I upgraded to RS&SP high end stuff, minus the hydraulic bump stops. I'm quite happy with them. While dealing with Rallispec can be like pulling teeth at times, I think it's worth it. I hit a rock that I never should have gotten away with, and yet they took it like a champ. Yes, they're a lot of $, but that seems to be a reality for rally suspension...
    Ryan Huber
    VA3AWD
    Any body selling their used or new suspension for GC Subaru?
    I will go with RSSP new it looks like...
    100 K right 4
    Dec 2003
    Peachland, BC, Canada.
    397
    If you are tight on budget, go with KSport... talk to Craig at XRoss in the supplier forum
    MJB
    Rally4Life
    don't cut HiTempguy's Avatar
    Dec 2006
    Red Deer, Alberta, Canada
    2,184
    Quote Originally Posted by markjb View Post
    Mark came something like 4th regionally in one of the most hotly contested regionals the WCRC has seen in years. On K-sports.
    As far as I am concerned, PFR is the 2nd roughest event in Canada. Hard to argue with a price of around $1500 for a set!
    Adam
    Blew up the clutch at PFR, back at it for Big White!
