1985 Audi 4000 Quattro Rally Car Build - Page 12
Page 12 of 12 FirstFirst ... 2101112
Results 111 to 115 of 115
Thread: 1985 Audi 4000 Quattro Rally Car Build
  1. #111
    100 K right 4 Alex's Avatar
    Nov 2009
    Vancouver, Canada, B.C
    269
    Quote Originally Posted by FRANK G. View Post
    Kendal the rod looks bent also,
    i had a bent rod once. it happened because of hydrolock when going through watersplash.
    wonder if the car went over water poddles and such?
  3. #112
    Quote Originally Posted by Alex View Post
    Unfortunately we did not make it to the water crossings before the knocking started. Although spectating on the second day of the rally we did see the Tiburon hydrolock and throw the rods out the side of the engine.
    We still think it was an oil pump problem but the bend rod is strange.
    _________________
    -Kendal-
    Audi 4000 Quattro Rally Car #154 [1(Road) 5(Cylinders) 4(Wheel Drive)]
    Audi 4000 Quattro Rally Car Build 1
    Audi 4000 Quattro Rally Car Build 2
    "but lay up for yourselves treasures in heaven, where neither moth nor rust destroys and where thieves do not break in and steal." Matthew 6:20
  4. #113
    the fact that it was the #1 rod leads me to think the oil pressure problem started it all. Could the rod have been bent the whole time? i.e. did you ever have the rod out of the block before this/do a compression test?
  6. #114
    We did have all the rods out. We weight matched the rods and pistons. I am sure we would have seen the bent rod if it was bent then.
    _________________
    -Kendal-
  7. #115
    How can I tell which one is the best broker among those mentioned on the list here?
    Sell rally car
