SALE: Subaru Parts, Rally parts and more....
Results 1 to 5 of 5
Thread: SALE: Subaru Parts, Rally parts and more....
    Default SALE: Subaru Parts, Rally parts and more....
    MASSIVE PARTS CLEAR OUT
    1. Most of the applications would be for Subaru Impreza GC and GD chassis,
    but some can be used on other models.
    2. Will make package deals
    3. There are also universal parts that can be installed into other vehicles.
    4. Parts can be used for the following applications:
    Street upgrade, Track, Race Rally
    5. Parts are USED unless marked as NEW, a brief description of the part(s) is attached.
    6. For more information please call or email, photos will be added ASAP.
    Prices do not include shipping, applicable tax or paypal fees
    7. Contact info: [email protected]
    8. Tel 905 877 1733
    9. Tel 416 562 5078
    Engine Components, Engine Management and Electronics
    Prodrive black silicone intake turbo hose, 1 piece available for the 2003-2003,
    WRX and STi (JDM) awesome for turbo restrictor applications $150
    Prodrive black silicone inlet hose NEW 2004-2007,
    the difference between this and the early version is the amount
    of output tubes/vac pipes. Awesome for Restrictor applications $200
    2002-2003 JDM STi Version 7 gauge cluster,
    this is a NON-DCCD cluster. $275
    2002-2003 JDM STi Spec C 12 L water spray tank complete with pumps $200
    Hydra EMS stand alone set up,
    o Plug and play for WRX, and JDM STi
    o You will need to retune for your application.
    o Version 2.5, will include wiring schematic for it.
    o Controls anitlag, water spray and launch control
    o $600
    Turbo Smart 4 port boost controller $65
    V34 turbo with 34 mm restrictor $750
    ** Bell mouth catless downpipe, $150.
    The flange for the bolt on mid section was remove and
    exhaust was welded. Some mods required.
    Stock WRX intercoolers with y pipes, no BOV, $135
    Driveline Components
    Transmisssion -- TY754VBAAA ,
    o 5 speed pull type transmission
    o JDM Impreza WRX & WRX STi
    o WRX/STi Ver.V - VI MY99-00
    o 4.44Viscous (4kgf)centre Open front diff.
    o $1450
    R180 4.44 rear diff complete assembly plated LSD $900
    Rear R180 complete hubs 5X100 bolt pattern.
    o Does not have e brake cables or shoes
    o $500/pair
    WRX Front axles $125 each
    WRX 5 speed propeller shaft $175
    Rear GD STi diff cross member
    o This cross member has the solid mounts
    o $150
    Interior and Exterior Accessories
    Impreza GC Carbon door mirrors, one reflector is missing. $250/pair
    Co-driver checker plate foot rest with brackets,
    o This is a universal fit
    o $50
    Large roof scoop and vent flap set
    o The flap is NOT the Grp N style, but it does fit under the larger scoop,
    works really well
    o Fiberglass upper roof scoop, Subaru fitment.
    o $275
    Aftermarket hood scoop, 2002-2003 fitment large.
    o Larger than JDM STi scoop
    o $50
    Dash board, upper section Flocked
    o Includes gauge cluster surround, also flocked
    o Upper heater vent on top of the dash, also flocked
    o Includes custom heater core and fan
    o Light weight
    o $300
    Under Car Protection and Mudflaps
    Front inner wheel well inner liners
    o Made from UHMW, white plastic
    o Fitment 2002-2003 WRX/RS
    o $100/pair
    Rear diff guard
    o Original Subaru unit
    o Steel construction
    o $70
    Mud flaps
    o Set of black urethane mudflaps.
    o Very durable and will fit most Subaru rally cars/rallycross cars.
    o $150/Set of 4
    Gravel, Mud and snow rally tires.
    Yokohama A034 winter rally tire.
    Awesome winter rally tire, can be used on snow, ice or a mix of surfaces
    One compound only, SOFT
    5 pieces remain, $185 per tire
    Yokohama A031 mud tire.
    205/65R15. (Actual size is closer to a 195/65R15)
    Exceptional mud rally tire, can be used on mix of surfaces such as mud and gravel.
    ( This is the tire that won Rocky Mountain 2010)
    Will also work on loose gravel
    4 pieces only, $175 each, selling in pairs or the set of 4.
    Dan
    Good Afternoon
    We have the following Components to offer.
    The items are listed on several posts.
    SUSPENSION
    Application: Subaru Impreza STi 2005-2007
    (With the front big knuckles and 5 x 114.3 bolt pattern.)
    One set of KYB high performance street/track suspension,
    Full coil-over, adjustable base for ride height adjustment which does not sacrifice ride quality..
    Adjustable dampening, with an extension for the rear shocks for easy access if installed into a car with rear seats.
    Inverted front shocks,
    Front and rear upper pillow ball mounts with camber adjustment at all 4 corners
    Uses “Swift” springs
    Used for testing only.
    Comes with coil-over adjustment tools
    NEW PRICE $1450 (New over $3000.)
    2005-2007 STi front shocks.
    3 sets front of 2005-2007 Front shock pairs.
    1 set of struts with under 6 000 miles, $250/pair
    1 set of struts with under 20 000 miles $200/Pair
    1 set of struts with under 40 000 miles $175/Pair
    2003 JDM rear STi shocks.
    Will fit from the 2002-2007 Rear WRX and STi suspensions
    $200/pair
    Rear Anti-Sway Bars
    • All original Subaru units
      These do not include: links, bushings or brackets.
      These will fit 1993-2007 Impreza L, RS, TS, WRX and some Legacy models that use the dual rear lateral link set up as the GC/GD models.
      There are some that will fit the 2004-2007 STi, that use the double tie rod style endlink.
    The following use the rear C-link style end link.
    • 4 pieces of the stock GC Impreza 13mm rear anti-sway bars.
      Some have surface rust but function properly
      $25 each
      3 pieces of the stock 17 mm,
      2001 and newer impreza rear anti-sway bars.
      A couple have surface rust but function properly.
      $40 each
      1 pieces of the JDM 20012003 STi 20 mm rear anti-sway bar.
      good condition but has surface rust as it was used on a street.
      $75.
    2005-2007 STi 20 mm rear anti-sway bar.
    These will not fit the cars that use the C-link style of endlink
    2 pieces 20 mm, rear anti-sway bars.
    Used but in good condition
    $25 each
    5 pieces of the 20 mm of brand new rear anti-sway bars,
    They still have the part number attacted.
    $55 each
    Endlinks-Front-Rear
    1 used set:
    Aluminum Anodized Blue front and rear set
    Rear C-link and front figure 8 design.
    Poly bushings
    $150 For the set of 4.
    BRAKES
    K-sport Hydraulic hand brake
    Vertical handle.
    3/4 master cylinder,
    Dial type hydraulic brake bias is also included.
    $250
    Front 4 pot / rear 2 pot : Originally the grey version
    Now painted gold. Used on a rally car.
    Good functional brakes.
    Include brake lines as in the picture.
    Can offer them with R180 or R160 rear 5 x100 set up
    And 5 x100 front rotors.
    Front calipers have PFC 01 race compound brake pads.
    $1000 for the set, will include the following:
    5x100 front rotors, 2 pieces
    5x100 rear rotors (either R160 or R180) 2 pieces.
    The steel braided lines, already attached to the calipers.
    The PFC front brake pads and a stock set of rear pads
    For more information please feel free to contact me by PM or email.
    Shipping, paypal fees and applicable taxes not included.
    Pick up is fine too.
    CONTROL ARMS, LATERAL LINKS, STEERING RACKS, MORE CALIPERS AND STEERING JOINERS ARE ADDED WITH PHOTOS
    Thank you
    Dan
    Four Star Motorsports inc
    Calipers Continued
    One Grey 4 pot caliper. Brand NEW. LEFT FRONT $225
    One Grey 2 pot caliper. Brand NEW. RIGHT REAR $200
    Rear Lateral Links.
    White Line adjustable lateral links
    WRX/STi/RS Fully adjustable front and rear.
    With poly bushings.
    These use the C-style sway bar end links
    Includes the rear cambolt eliminators
    Set of 4, 2 forward and 2 aft arms.
    $275/ set of 4
    2004-2007 STi Fitment
    Rear STi pink lateral links
    Brand New.
    Pillow ball mounts inner and outer mounts.
    $500 SET of 4.
    2004 Rear STi black lateral links
    Used set.
    $225 SET of 4.
    FRONT LOWER CONTROL ARMS
    2002-2003 JDM lower front control arms, pair complete with NEW Power flex front bushing $375 pair.
    One single Version 7 control arm LH front complete new, $245
    One single version 7 control arm LH front complete used, $175
    One version 8 lower control arm, excellent condition $200
    STEERING PARTS CONTINUED ON THE NEXT POST
    STEERING COUPLERS
    Both of these are fine spline count.
    WRX versoins with rubber joiner, ujoints in very good conditons.
    $35
    STi double ujoint versions, excellent conditon
    $55
    STEERING COLOUMNS
    These steering coloumns do not include ignitions.
    I have new and used one.
    All of these are from 2002-2007 Impreza/WRX/STi, fine spline count.
    NEW $125
    USED $75
    STEERING RACKS.
    2005-2007 STI RACK, 2.6 TURNS LOCK TO LOCK
    Low mileage unit, excellent condition $400
    34110 FE600
    2005-7 WRX WAGON FITMENT STOCK RACK.
    Low mileage, excellent condition.
    $300
    2002-2004 WRX steering racks.
    I have supplied the KOYO numbers of the ones I have
    Please email for your needs.
    One of each
    KOYO # 2X10113
    KOYO # 1Z19067
    KOYO # 0Z25014
    2005-2009 LEGACY QUICK RACKS.
    $1500
    THESE WERE BUILT IN EUROPE FOR MOTORSPORT USE.
    BUILT FROM CORES THAT HAD LESS THAN 1000 MILES.
    INCLUDES BELLOWS AND NEW INNER TIE ROD ENDS.
    Photo of one of the Legacy racks
    FOR 2005-2009 LEGACY OUTBACKS 2.5 & TURBO or 3.0H6 ALL
    FOR 2005-2009 LEGACYS (except SPEC B & except 3.0R Limited)
    RIGHT HAND DRIVE RACKS
    (I can show the part number re vehicle application if need be from the Subaru JDM parts book)
    34110FE150 JDM 2002-03 version 7 Spec C rack, old style fitment. 13:1
    $275
    34110FE230 JDM 2002-03 version 7 STi/STi Prodrive/STi LTD fitment.
    $275
    34110FE440 JDM 04 Version 8 Spec C rack, old style fitment. 13:1
    $325
    34110FE550 JDM 06-07 Version 9 Spec C, new style fitment 13:1
    $375
    34110AG010 JDM 2003-2005 Legacy Subaru Legacy / TA-BP5 RHD,
    $225
    Also in stock RHD power steering lines.
    Please feel free to email me for your specific needs.
    Thank you
    Dan
    Four Star Motorsports Inc
    We have the following wheels on special pricing.
    Speedline 2113
    Subaru 2005-2011 STi fitment (will clear Brembos without issue)
    Size 17x8
    Bolt Pattern 5 x 114.3
    Offset ET 49
    Subaru hubcentric.
    Gold in colour
    These are a very strong wheel, can be used for regular street, winter rims or
    track use.
    $250/Wheel, (They were $275/wheel.)
    One used set of Speedline 2113
    Will clear Brembo brakes without issues.
    These wheels are are straight just have cosmetic scratches.
    Size 17x8
    Offset ET 49
    Subaru hubcentric.
    Gold in colour
    track use.
    $725/set of 4 (was $775)
    Braid" 16 Motorsports wheels
    These are used but in excellent condition.
    These wheels are for the narrow race and rally tires for snow events or ice racing
    2005-2011 Subaru STi fitment
    Size 16x5.5
    Subaru hub centric
    White in Colour
    $150/wheel (Price was $175)
    Enkei STi Ltd and JDM wheel. 2005-2011 Sti fitment. USED
    Original Subaru wheel.
    Clears Brembo brakes.
    Size 17x8
    Offset ET 53
    Subaru hubcentric.
    Gold in colour
    One piece only, can be used as a full size spare
    $175/Wheel (Price was $195/wheel)
    New items to clear out, added the following wheels.
    Subaru fitment: original 16 Impreza TS (pre 2001) 5x100
    3 pieces only.
    They are in very good condition, it is the thin spoke design.
    Rims can be sold individually and tires thrown out
    $125 for all 3 or $50 each.
    Subaru fitment steel wheels
    Painted white.
    16x6.5 5x100,
    Clear stock WRX brakes and the 4 pot/2pot set up. (not Brembos)
    Will fit other cars, these are aftermarket steel wheels not original Subaru.
    These are not hubcentric.
    6 in total, good to very good condition.
    $200 for all 6 or $40/each.
    Dan
