Fire Suppression Systems, Free Shipping on all ESS Fire 2.3L and 5.0L Systems!
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Fire Suppression Systems, Free Shipping on all ESS Fire 2.3L and 5.0L Systems!
    Thumbs up Fire Suppression Systems, Free Shipping on all ESS Fire 2.3L and 5.0L Systems!
    ESS 2.3 Liter Fire Suppression System.
    $409 with free shipping to the lower 48 states, USA. LINK
    The ESS 2.3 liter system is approved by SCCA, NASA, PCA, BMW Club, and others for competition and track days.
    This is a 3 nozzle system utilizing our T-style nozzle design, a bulkhead tee fitting for two nozzle coverage of the engine compartment, all fittings, stainless steel mounting brackets, pull cable activation, our re-designed pull cable mounting bracket for easy installation, 10 ft. aluminum tubing, and detailed instructions
    This system is a two zone system. It is designed to give protection to two zones in the event of a fire - most commonly the driver and the engine. In place of the engine the fuel cell could be the second zone.
    Key Benefits
    Excellent coverage through the use of the new T-style nozzles
    Field rechargeable in under a half hour
    Easy to remove for technical inspection
    Included Parts
    Spun cast aluminum cylinder Aluminum 2 port head
    Slotted pull cable bracket Adjustable length pull cable
    Safety cup and pin for pull handle Safety pin for cylinder actuator
    2 -4 AN to 1/4" NPT head fittings 1 -4 AN bulkhead tee and nut
    8 -4 AN nuts and sleeves Insulated "D" clamps
    10ft. 1/4" aluminum tubing
    3 T-style nozzles
    2 Stainless steel t-bolt band mounts with integrated feet
    Non-fracturing head seal
    8 oz. AFFF concentrate
    Emergency "E" sticker
    Detailed, illustrated instruction manual
    Made in the USA
    WARRANTY: Emergency Suppression Systems, Inc. certifies to the first end-user that the ESS product they purchased is free from defects in material or manufacturing, under normal use, for a period of three years. If the product is found to be defective during this warranty period, ESSís liability and the purchasers sole remedy shall be at ESSís option to (1) repair or (2) replace the product or (3) refund the purchase price of the product,, after the product has been returned to ESS with the proof of purchase. If the failure is determined to have been through misuse, abuse, accident, neglect, mishandling, or modification of any kind, ESS will have no responsibility to repair. replace, or provide refund for the product.
    ESS 5 Liter Fire Suppression System.
    $509 with free shipping to the lower 48 states, USA. LINK
    The 5.0 liter system is a racing approved system by SCCA, PRO-SCCA, Trans Am, World Speed Challenge, American LeMans, NASA, and others.
    This is a 4 nozzle, 3 zone system utilizing the newest T-style nozzle, bulkhead fitting, 20 ft of aluminum tubing and the other features of the 2.3 liter system. This system is available as an owner rechargeable system and as a SFI 17.1 compliant system. The SFI 17.1 compliant system requires that the systems be shipped full, sealed, and certified for 2 years of service. We offer a re-certification program for both 17.1 and non-17.1 systems. Call our offices for more information or request information by writing to [email protected].
    This system was created for the hardcore racer. It is designed to provide three zones of coverage - driver, engine, and fuel cell. The aluminum cylinder and hardware keep down the weight and yet the 5 liters of suppression agent provides better coverage than the competition. The 5 liter system will produce approximately 30 liters of foam when activated, enough to subdue the most stubborn fire. In non SFI 17.1 compliant systems, you clean up with water and can recharge the system at the track with a recharge kit (retail under $70) and fresh water. The SFI 17.1 compliant version of the 5.0 liter system requires that the system be shipped back to us for recertification. We offer a re-certification program for both 17.1 and non-17.1 systems. The stainless steel t-bolt mounting brackets allow easy access for tech inspection and storage during the off season.
    Contact your sanctioning body if you would like to use this system.
    Key Benefits
    Larger coverage area than the 2.3 liter
    Meets or exceeds most sanctioning body requirements
    It is also available in AFFF-AR for use on alcohol based fires
    Included Parts
    Aluminum 3 port head
    3 -4 AN to 1/4" NPT head fittings
    10 -4 AN nuts and sleeves
    20ft. 1/4" aluminum tubing
    4 T-style nozzles
    12 oz. AFFF concentrate
    Made in the USA
    Best regards,
    Charles Buren
    www.safedrives.com
    877-739-1713 Toll Free
    Hi All,
    I just wanted to point out that all of these ESS Systems are self serviceable. You can recharge / refill the system yourself. It's basically soapy water foam that comes out when the system goes off. So it is a very simple, yet effective type of system.
    Also, this kit is available with SFI Certification. Whilst this certification is not required by the rally rule books, it is nice to know that this system is certifiable, just like the rest of us.
    Best regards,
    Charles Buren
    www.safedrives.com
    Questions welcomed. =-)
    Best regards,
    Charles Buren
    www.safedrives.com
    Bump for safety.
    Bump for big, big upgrade in safety.
    Happy day to you!
    Going up for safety!
    *Loves the safety*
    Thank you SS!
    *Ships daily*
    Best regards,
    Charles Buren
    www.safedrives.com
