Padding, FIA - SFI - Sheet - Dual Density - Only the Best Available - Made in the USA
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Padding, FIA - SFI - Sheet - Dual Density - Only the Best Available - Made in the USA
    Default Padding, FIA - SFI - Sheet - Dual Density - Only the Best Available - Made in the USA
    All we sell at safedrives.com are auto safety products.
    As you can imagine, we did a lot of research to make sure that we sold only the best roll bar padding. We found that the folks at BSCI pioneered and fought for new roll bar padding standards at the SFI and FIA in the late 1990s.
    The padding that BSCI produces is SFI or FIA certified. It also meets the strict Federal Motor Vehicle Saftey standards for head impact protection in an automobile(FMVSS 206.u and 302). The only pad that we know of meeting this standard.
    Which style is best for you?
    FIA: For rally cars This is the best padding.
    For street driven vehicles we really try to steer our customers to the FIA certified pad. It's thicker and as such will absorb more energy in an impact. It is sold in a three foot length for $20.95
    For more information on the BSCI FIA certified padding please go here http://www.safedrives.com/prod...at=72
    SFI:
    The SFI certified pad is made from the same material as the FIA pad. As such it carries the same FMVSS as the FIA pad. It is not as thick as the FIA pad though. Since it has less material the cost is less as well as the weight. The same three foot length is $18.95.
    For more information, or to purchase the BSCI SFI certified padding please go here http://www.safedrives.com/prod...at=72
    Both are only available in Red, Blue or Black.
    Dual Density: (Great for Doorbars!)
    BSCI's SFI 45.1 Approved Dual Density Roll Cage Padding System. $39.95
    This padding has two parts that create one padding system. The inner part is a SFI 45.1 approved padding that is very dense and will help to save your skull in the event of a heavy impact like any other SFI 45.1 approved padding. The outer part of this system is made of a softer padding so that at lower impacts the padding will feel a lot nicer.
    Perfect for street driven vehicles that have roll bars and cages.
    Perfect for roll cage door bars where you are always hitting your knees and elbows.
    This padding looks just like the FIA rated padding, in fact the outter part of the system uses the FIA padding molds. However the outter cover portion is very soft to the touch, almost rubber like, but yet fire resistant.
    Available in black only.
    SFI 45.2 Sheet Padding:
    No Image
    Made from the same material as the BSCI Roll Cage padding.
    Roll bar padding is not just roll bar padding. Tests have proven that roll bar padding plays a vital role in decreasing the potential of serious injury in crashes.
    The BSCI padding set the industry standards for quality and proven additional safety. The materials used to manufacture the BSCI padding were formulated to absorb impact, which in turn reduces impact energy received by the driver.
    A unique dimension of the BSCI pad is its ability to wrap and twist around the bars in the roll cage without breaking and cracking. Its application eliminates the need for sizing and cutting the padding so as to avoid breakage on turns and bends in the roll bar.
    Will not melt or burn.
    Comes in black. Custom thickness and colors are also available. Call for details.
    These are all in stock and ready to ship out the next day. :thumbup:
    Thank you for looking at this ad. =)
    Best regards,
    Charles Buren
    www.safedrives.com
    877-739-1713 Toll Free
    Bump!!!
    Going to the top!
    Best regards,
    Charles Buren
    www.safedrives.com
    Thumbs up
    Bump for a new image.
    Thicker = Safer
    Best regards,
    Charles Buren
    www.safedrives.com
    Now selling 1 inch thick SFI Certified Sheet Padding by the square inch! You'll have to call me to order that though. Also available at Oregon Trail Tech if you wnat to put a piece on your B pillar for example.
    Best regards,
    Charles Buren
    www.safedrives.com
    Bump for great products.
    Quote Originally Posted by Safe Drives View Post
    This offer is still available and is just a great deal at only 10 cents per cubic / square inch.
    Best regards,
    Charles Buren
    www.safedrives.com
    Bump for great padding!
    Co-Drivers,
    Put a sheet of this under your bottom to help out on big landings.
    Best regards,
    Charles Buren
    www.safedrives.com
    All roll bar padding colors and styles are in stock and ship weekdays.
    Best regards,
    Charles Buren
    www.safedrives.com
    I have SFI sheet foam in stock and sold by the cubic inch.
