Diode Dynamics: SmartTap CF18 (LM449) Flasher Relay! Add One-Touch Signaling / Strobe
+ Reply to Thread
Results 1 to 8 of 8
Thread: Diode Dynamics: SmartTap CF18 (LM449) Flasher Relay! Add One-Touch Signaling / Strobe
    Apr 2014
    St. Louis, MO
    103
    Wink Diode Dynamics: SmartTap CF18 (LM449) Flasher Relay! Add One-Touch Signaling / Strobe
    Designed and Manufactured in St. Louis, Missouri!
    The SmartTap™ is a replacement turn signal flasher module compatible with any vehicle using a CF18 (LM449) Flasher. Programming each mode is simple with the help of the included programming guide and the use of existing vehicle controls.
    Tap-to-Signal: One-touch signaling is a convenient way to signal to other drivers when switching lanes. Simply tap the turn signal for a series of signal blinks.
    Arrival and Departure Modes: When the lock or unlock button is pressed, the surrounding area will illuminate for better visibility when approaching or leaving the vehicle at night. The lighting time can be adjusted from 10-90 seconds for additional illumination, or disabled if desired.
    Unique Hazard Functions: The SmartTap™ has built-in strobe, slo-mo and wig-wag hazard functions to help the vehicle stand out when the hazards are on. Apply these functions on their own, together or with the strobe setting for a total of EIGHT unique hazard functions!
    This product was designed and fully manufactured by Diode Dynamics, in St. Louis, Missouri. It is fully made in USA.
    All products by Diode Dynamics are backed by a 30-day satisfaction guarantee and a three-year limited warranty.
    Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
    *PM us for the free-shipping code* (U.S. forum members only)
    Thank you!
    Nick C.
    Diode Dynamics
    Wig-Wag Function!
    Apr 2014
    St. Louis, MO
    103
    How to Program the Diode Dynamics SmartTap™ CF18 (LM449) Flasher Relay
    Thank you!
    Nick C.
    Apr 2014
    St. Louis, MO
    103
    Diode Dynamics Smart Tap CF18 Flasher Relay Overview, by Lightwerkz
    Apr 2014
    St. Louis, MO
    103
    SmartTap Wig Wag Strobe!
    Nick C.
    Apr 2014
    St. Louis, MO
    103
    Don't forget to send us a PM for the free-shipping code!
    (U.S. members only)
    Thanks!
    Nick C.
    Apr 2014
    St. Louis, MO
    103
    SmartTaps are in stock and ready to ship!
    Thank you!
    Apr 2014
    St. Louis, MO
    103
    Wig-Wag Strobe on an XV Crosstrek!
    Nick C.
    Apr 2014
    St. Louis, MO
    103
    The SmartTap works perfectly on the 86!
    Big thanks to Pappas Toyota for letting us borrow a brand new Toyota 86!
+ Reply to Thread
