Subaru WRX/STI Fog Light LED Bulbs! Luxeon LED Housing Replacements! Yellow XML2!
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: Subaru WRX/STI Fog Light LED Bulbs! Luxeon LED Housing Replacements! Yellow XML2!
    Apr 2014
    St. Louis, MO
    138
    Default Subaru WRX/STI Fog Light LED Bulbs! Luxeon LED Housing Replacements! Yellow XML2!
    Subaru WRX / STI Fog Light LED Bulbs
    We carry LED bulbs for replacement of your Subaru WRX/STI's fog lights, in all major sizes. They are available in HP, XP, and XML styles. This will make your fog lights a nice bright white that closely matches factory HIDs! Just simple plug and play, replace the bulb and you are good to go! We also offer Luxeon LED Housings for a complete replacement of your factory fog light housings (2015+ WRX/STI Model Years)
    We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
    Brightness:
    Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
    HP48: 265 lumens. Lower brightness than factory, but still provides the crisp white, modern color of LEDs.
    XP80: 510 lumens. Similar brightness to factory.
    XML2: 1420 lumens. Much brighter than factory. These are bright!
    *XML2 is available in Yellow 3000K / 4000K / 5000K / 6000K Color Temperature Options*
    Luxeon LED Replacement Housing: Powered by three genuine Luxeon T LED chips per side, the perfect 5000K white color provides a brilliant LED illumination, with a Trulux measured output of 600 lumens. (Please note: similar styles of lamp can be found online which claim much higher output, but these numbers are highly inflated. These lamps are the brightest on the market!)
    Bulb Design
    HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
    XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
    XML2: NEW! Two opposing genuine CREE XM-L2 chips, driven at high power by self-contained regulator unit, in an attractive cast-aluminum housing. Fully waterproof, non-polar, modular design.
    These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
    Luxeon LED Replacement Housing: Integrated projector lens distributes light in a wide, even pattern, compliant with DOT and ECE standards for use on-road. With a durable poly-carbonate lens, aluminum housing, and constant-current drive circuit, these LEDs will be durable and reliable for years to come.
    Included in your order is TWO BULBS (to fit your WRX/STI).
    All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
    Click below for more info or to order:
    Subaru WRX Fog Light LED
    If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call: (314) 205-3033
    *PM us for the free-shipping code* (U.S. forum members only)
    Thanks for looking!
    Nick C.
    Apr 2014
    St. Louis, MO
    138
    Send questions to: Contact@diodedynamics.com
    Apr 2014
    St. Louis, MO
    138
    PM responses sent!
    Nick C.
    Apr 2014
    St. Louis, MO
    138
    Apr 2014
    St. Louis, MO
    138
    If you've taken pictures with Diode Dynamics products installed, please share them with us!
    Send them to: contact@diodedynamics.com
    Thank you for your support!
    Nick C.
  8. #6
    Apr 2014
    St. Louis, MO
    138
    PM responses sent!
    Thank you,
    Nick C.
  9. #7
    Apr 2014
    St. Louis, MO
    138
    Don't forget to send us a PM for the free-shipping code!
    (U.S. members only)
    Thank you,
    Nick C.
  10. #8
    Apr 2014
    St. Louis, MO
    138
    Questions? Give our team a call: (314) 205-3033
  11. #9
    Apr 2014
    St. Louis, MO
    138
    (314) 205-3033
  12. #10
    Apr 2014
    St. Louis, MO
    138
+ Reply to Thread
