SA2010 Rated Peltor
+ Reply to Thread
Results 1 to 2 of 2
Thread: SA2010 Rated Peltor
    May 2008
    Oxford, Penna.
    311
    Default SA2010 Rated Peltor
    Whilst perusing the interwebs today, I cam across some helmet porn I figured was worth a share:
    https://content.foreningshuset.se/Ku...data_sheet.pdf
    I find it interesting that 3M/Peltor is finally offering a helmet option that is SA rated. Unfortunately it doesn't look like it's designed to take the noise reduction cups like the G78/G90 variants, but rather is uses in ear plugs (ala F1) that are designed to work with the FMT based intercoms. This really makes me wonder if it's truly a Peltor, or if they are re-branding another offering (Sparco is now selling helmets with Peltor stuff pre-installed)
    MAYBE we'll see SA certification of an open face Peltor helmet with the noise reduction cups and coms? Time will only tell...
    Nov 2004
    SE Wisconsin
    1,805
    The BSI certification is expiring, so they had to make some switch.
    A little searching on the "new Cone-head® liner" would lead me to believe these are being produced in China by a mfg. partner to be sold under the Peltor name.
+ Reply to Thread
